Hi All
I'm looking for a 904 mainshaft for my 901 race gearbox rebuild. If you have an excellent condition used or can do me a good deal on a new one please let me know.
Steve
Hi All
Steve
Steve
I think Lisa @ Spyder had one of these but it may have been earmarked for someone.....
Looking for engine # 6208151
'74 RS 3.0 Replica
'70 911E Bahia Red (SOLD)
'71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
Australian TYP 901 Register #78
Early S Registry # 1076
Hi and thanks for the info really appreciate it. I'm having trouble finding an email or contact details for Lisa can you point me in the right direction?
Steve
Use a GA main...they are available (and way cheaper). GA is a fairly usable 2nd-unless you're building up a giant, gorilla motor. I use GAs in my track boxes. They work pretty well.
Another thought would be to get next to a machinist, and fabricate a "new main" (from the old one) with the gearset of choice fitted to it...problem I see with that is that it's a "one shot deal" (no interchangeability). I've also never tried converting one: don't know how well that works, if at all.
I'm suprised no one has done a batch of 904-spec mains...(or am I missing something completely there?)
Hope this helps - think about that GA main as an alternative.
cheers
Thom Kuby
Contact Ottos
Juan - Member # 321
Ft. Lauderdale
Klub Sport Champion
Rolex Endurance Champion
HSR Sprint Champion
PCA Club Race Champion
Thanks for the advice Thom, I've had a couple of leads that I'm currently chasing but if they don't work out I'll explore the option you've suggested. The rules for the HSCC Historic roadsport championship are fairly limited (which IMO is a good thing cos it keeps the cost down) but I'm limited to a single plug 2.0 MFI engine (+40 thou overbore) with standard rods and no exotic materials ie no titanium so it's not going to make much more than the standard 170-180hp. The car has to be 975 kg's so I thought if I can make the most out of the gearing it'll go some way to offset the limited engine tuning.
Steve
Regs are here
http://www.hscc.org.uk/PDF%20Forms%2...egs%202006.pdf
Steve,Originally Posted by ixxifan
This configuration is real close to what I'm running out here on the west coast...I'm one of the very few (I think there's 3 of us) all steel 2-liter 911s left in my organization (VARA). The rest of em went to big motors, and lots of plastic panels. fortunately no flares or spoilers are allowed on the CP Porsches in VARA... No, I don't run up front, but then again I really don't care...as long as I'm totally focused, driving 110%, and I've got somebody to mess with, it's all good...
but I digress:
I only weigh 200lbs less than your minimum weight...If I were to build and run JUST ONE transmission; I would strongly recommend A, GA, K, Q, V gears. This makes for a great all-round gearbox. I call this my "medium" box. I have a "long" M,S,X box that's really too tall for anything, except maybe Daytona, or Nurburgring...rare is the time I see fifth gear when I run that box. I'm thinking about shortening that one up just a few hairs.
I'm also building a "short" box that's a couple of ticks shorter than the K,Q,V setup.
Steve, if you'd like I can pass along a neat spreadsheet (MS excel) tool that a friend setup for me. it gives you all the possible gear combinations & scenarios. You enter the car's weight, wheel/tire diameter, your gear choices, and a shift point. The tool does the rest. I think you'd get some insight from it to help you along on gear decisions...I use it all the time.
Let me know...
Cheers
Thom Kuby
Steve
Go to private messages at the top of the screen, then click on send message and type in lisa in the recipients box. Should get you started. Good luck.
Oh by the way she is is Australia so postage might be a bit steep!
'74 RS 3.0 Replica
Great photo, Thom!Originally Posted by Homemade 911
Best regards,
Tom
Early S Registry #235
rgruppe #111
Thanks for that I'll drop her a mailOriginally Posted by Cam Arnott
