Thread: Piston crown numbers
    Isn't chemistry always nano?
    Aug 2006
    Howdy all:
    I posted over a pelican, but have not had much success. Can anyone enlighten me as to what the numbers that are on the piston crown mean? They are Mahle 92mm pistons.
    This is as they are shown in the picture:
    200
    0899
    1
    24/6
    91.89
    and cast into the inside skirt is 195 (on the intake side).
    The 91.89 is the piston diameter as that is exactly what it measures in mm.
    Any guesses on the others?
    Thanks in advance,
    tadd
    I think the #1 is the weight class. They used to put this in a triangle.
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    Aug 2006
    Any idea what that corrsponds to?
    tadd
    according to me the big "1" is the tolerance group of the piston.
    The one at the bottom is the new diameter.
    they are nubered 0, 1 or 2 and normally they are used in a corresponding set of cilinders (they also have these tolerance groups)
    The figure in a triangle should be the height tolerance group of the cilinder.
    No clue about the rest....
    Tadd,
    Info is from the "Pistons Manual" Nural, Alcan Deutschland GmbH.
    Ernie W
    member of Early 911S Registry
  1. POC Triple Crown at Willow Springs Raceway
    By Flieger in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 05-01-2011, 11:52 AM
  2. POC racing at Willow Springs: Triple Crown
    Last Post: 05-03-2010, 04:34 PM
  3. Porsche Part Numbers to Bosch Part Numbers
    By FL-Frank in forum General Info
    Last Post: 06-28-2009, 08:56 PM
  4. VIN numbers and dash rail numbers
    By davidppp in forum General Info
    Last Post: 08-21-2007, 09:01 AM
