Results 1 to 10 of 16
Thread: Weber 40 IDS question
    Senior Member 68S_SK2's Avatar
    Mar 2006
    Munich, Germany
    Are the Weber 40 IDS velocity stacks made out of plastic or metall?
    What is the original configuration for a SWB 911S? When was it changed?
    Thanks in advance.
    Claudius
    Goldmember ttweed's Avatar
    La Jolla, CA
    My IDS carbs have metal velocity stacks.
    The original configuration for the SWB 911S included 40IDA-3C carbs, same as the Normal version, but with larger venturis and jetting for the hotter motor. From engine serial #960502 on, the 911S used the 40IDS-3C carbs, which had the added high-speed enrichment circuit to provide a richened mixture at high RPM to minimize the possibility of detonation.
    If I remember correctly, the 2.0S carbs originally had 32mm venturis, 130 main jets, 180 air correction, 55 idle and F3 emulsion tubes, if that is what you mean by "configuration."
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Both my 67S and 67 Normale have metal. I just bought an extra set of carbs from Rob Laverty and they have plastic, he said they were from a late 67. I have a set of plastic that I remember coming from a 71T.
    Rick
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    Mar 2006
    Munich, Germany
    Thank you Tom and Rick!
    Sorry for the confusion, but my question was originally focused on the material of the velocity stacks - metal versus plastic.
    I have got both too, but what is original for an early SBW car??
    Claudius
    5 of mine are plastic.
    I assume the originals were plastic and one was broken and replaced with metal.
    Joe
    Now - 1993 C2
    Past - 1968 911L
    Metal.....
    Mar 2006
    Munich, Germany
    It is looking like half and half - plastic and metal....letīs make a poll?!
    As far as I know it was changed in 1971, but I have now idea whether metal was first or the other way round??
    It seems to be a difficult question!
    Who knows??
    Claudius
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Bump to see what eventuated
    Mark
    Quote Originally Posted by NZVW View Post
    I seem to recall the 67s being plated metal, and the 68s being plastic. Paul Abbott will know.
    Jon B.
    Vista, CA
    Junior Member
    Sep 2017
    Belgium
    Hi,
    Indeed, my 68 2.0S have 6 plastic ones.
    Regards,
    Fred
  1. CIS to Weber conversion question...
    By joeblow in forum Technical Info
    Last Post: 08-04-2010, 02:42 PM
  2. Help! - Weber question
    By gilbert911 in forum General Info
    Last Post: 12-06-2006, 02:25 AM
  3. Weber Question 40 IDA v. 40 IDS
    By t6dpilot in forum Technical Info
    Last Post: 11-21-2006, 12:55 PM
  4. Weber question.......
    By Markus in forum Technical Info
    Last Post: 10-25-2002, 08:36 AM
