Thread: Oil drain plug and tank wrench
    Changing the oil in my just received 911e. Just discovered I don't have the proper wrench for the two plugs. What size is it? Obviously, my first 911. I tried doing a search and nothing came up.
    Thanks for any help. This site helped me tremendously in making this purchase.
    911 S Registry # 1054
    1970 911 E Coupe Signal Orange (#1414)
    1979 BMW 320i
    2001 Boxster S
    2003 Audi Allroad 2.7T Tiptronic
    2014 Jetta Sportwagon TDI DSG ( sold back to Volkswagen)
    2015 Allroad 2.0 TFSI
    Jan 2006
    Naperville, IL
    Are the drain plugs allen type-hex or are they a head like a socket(19mm)? Does your car have a tool kit?; I think the either one will be in the tool kit.
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    I just did my first oil change the hex heads are 15 & 19 be shure to have 2 very large drain pans
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    My drain plugs appear to take either an allen wrench or a torx. I couldn't really tell because they have been "buggered" up a bit. On second thought, torx type heads probably weren't around in 1970. Based on your comments they are probably an allen wrench. Thanks for the information. Yes, good point. That engine holds over 7 quarts of oil. I'm off to buy the allen wrenches. I don't have any that large. My car didn't come with a tool kit just a jack. I am looking for a tool kit as we speak.
    1979 BMW 320i
    2001 Boxster S
    The internal hex drain plug uses a 10mm hex bit. Use a socket drive and attach a 1/2" dr. breaker bar to it. These tend to tighten up with miles. Many folks end up with an unremoveable frozen plug. I'd recommend a Fumoto ball drain valve to replace the factory drain plug.
    Sherwood
    Sherwood -
    You are correct, it's a 10 mm hex socket. Hex bit and ratchet worked just fine. Plugs came out without any problem. Just finished changing the oil along with the filter screen. Engine has just been re-built and I found a few tiny pieces of gasket material in the screen.
    1979 BMW 320i
    2001 Boxster S
  1. Sump Plate with Drain Plug...Where?
    By dave29 in forum Other Porsche Passions
    Last Post: 09-26-2012, 08:53 AM
  2. WTB - Tool Kit Klein spark plug wrench and 17/19 wrench
    Last Post: 03-25-2012, 09:24 AM
  3. WTT My Spark Plug Wrench for Generator Wrench
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 10-16-2010, 10:58 AM
  4. WTT or BUY 911 Generator wrench, 356 Spark Plug wrench
    Last Post: 02-18-2008, 07:08 PM
