Results 1 to 7 of 7
Thread: 911R struts and calipers
    I've been lurking on the site and can't seem to find my answer.
    What strut and caliper combination did the 911R come with?
    Todd Rudaitis
    Tustin, CA
    Jul 2003
    Santa Cruz, CA
    I think the calipers were the 906 variety?
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Aug 2006
    Sonoma, CA
    911R Front Calipers
    I believe the calipers were 901.351.043/4.20 variety. These would have bolted up to the 911S Koni front struts from the period. I think the front suspensions were the "combination" old control arm with new T-bar fittings that was common on the 1968 cars. These would include the "itty-bitty" ball joints and preclude the bigger front calipers that came with the '69 and later iterations of the front suspension.
    There are those who know better who can correct my errors.
    johnt
    Second item down:
    http://www.elevenparts.com/index2.php?f=rare&p=racing
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    I think the R used calipers from the 908.
    The Calipers on the Lt. Are defiantly 908, (914/6 GT, 911ST) the ones on Rt. seem to be regular 911S fronts. I don’t think the Alloy “S” caliper will bolt on to the early short wheel base control arm? Also, using calipers with large pistons front & rear will most likely produce a soft brake pedal, not to mention upsetting the front/rear brake bias. Or is there some type of adaptor, larger Master cyl. And brake proportioning valve that was also used? I am also curious what the holes are for on the body of the calipers that faces the wheel; I have never seen those before. Any idea’s?
    Bernd Buschen
    R Gruppe # 357
    71' 914-6 Original Owner
    70' 914-6 GT Stoddard Built
    69' 911E Scott's car
    70' 914-6 Sold
  1. WTD: adapters to fit alu frt calipers to SWB struts
    By preS in forum For Sale: 911 Parts
    Last Post: 04-27-2010, 10:52 AM
  2. Struts and calipers for sale
    By ret9191 in forum For Sale: 911 Parts
    Last Post: 12-13-2007, 07:28 AM
  3. Wanted Bilstein front struts and alloy calipers
    Last Post: 08-08-2007, 10:50 AM
  4. "S" calipers and Koni struts
    By LUNARTI in forum For Sale: 911 Parts
    Last Post: 02-20-2007, 10:13 AM
  5. "S" aluminum calipers, KONI struts
    Last Post: 02-19-2007, 01:26 PM
