Thread: Parts for sale
    Parts for sale
    Porsche pieces for sale:
    Fuel system:
    Fuel tank sending unit, $20
    Weber parts:
    Banjo bolts (4 avail.) $8 ea.
    Banjo fittings, single inlet, (2) $24
    Venturis, 27mm (6), $30
    Emulsion tubes, F1 (6), $30
    Main jets, 110 (6), $20
    Float pivot screws (4), $6.00 ea.
    Float needle assy (6) replaced w/Grose jets, no leaks, $10 ea.
    Intake manifold, 40mm. Port-matched to 36mm, $200
    Brakes, Suspension:
    Koni shocks, used, $40/pair:
    82K-1756 (rear 72-73), 2
    80K-2088 (rear 69-71), 2
    8.0J-205 (rear ??), 2
    82R-1394 (front 65-68, some 69), 2
    Rear torsion bars, 24mm factory, $40/pair
    Early 911 rear spring plates, $20/pair
    944 Turbo rear caliper (30-28mm pistons), $120/pair
    84-on Carrera caliper, rear (1 only), $50
    89-94, 1-piece front rotors, new (298x28mm) (2), $100
    Body, Interior:
    Top rear quarter panel trim strip, burgundy, $25/pair
    Quarter window glass, $10 ea.
    915 shift housing boot, $9.00
    901 shift housing boot, $10.00
    Rear engine lid gas strut, near new, $10
    Rocker panels, narrow body, rough 75-76, $20/pair
    Engine:
    CIS intake manifold hose, 3-ply silicone (74-77, 80-83), New, $20/6 or $4 ea.
    ITG air filters (2), New. JC40/40 with 2 sets mounting plates, $200
    Engine lid dual strut conversion bracket set, $12
    Engine chain box, mag. L/R, $35 ea.
    Crankcase engine breather cover, '69S with thermo switches, $65
    Engine tin, rear, ~1975 (2 avail.), $30 ea.
    Engine motor mount crossbar, early unthreaded ends, $35
    Engine mount cradle (engine to crossbar), $25
    Marelli distributor with good cap and rotor, $100
    Delta Mark 10 CD ignition box, $50
    Some pics:
    http://members.rennlist.org/911pcars...-pcarparts.htm
    Note: Some parts pictured may already be sold.
    Sherwood
    Your Stuff
    PM Sent..........
    J-P
    ______________
    S Registry #949
    Weber parts and shift boot
    Hi Sherwood,
    I'm interested in the emulsion tubes, main jets, and 901 shift boot. I'll send you a PM.
    Alan
  1. Replies: 7
    Last Post: 07-29-2012, 04:43 PM
  2. Early 911s parts for sale 911 parts needed
    By expernet in forum For Sale: 911 Parts
    Last Post: 11-29-2010, 02:42 AM
  3. Early Carb parts for sale also small parts
    By mcvwbugs in forum For Sale: 911 Parts
    Last Post: 07-28-2009, 10:38 AM
  4. Moving Sale: Many early 911 parts and parts cars F/S
    By JPlonghood in forum For Sale: 911 Parts
    Last Post: 02-23-2009, 11:40 AM
  5. Replies: 0
    Last Post: 11-03-2007, 01:42 PM
