Yeah, yeah....this is a cross-posted thread, but only because I know there are some Early 911S guys that don't go to Pelican. I have a lot of early 911 engine and MFI parts that you guys might be interested in...here goes:
Crankshafts & Connecting Rods
-3.0L 911SC Crankshaft, 9-bolt 70.4mm, Std/Std, Excellent, magnafluxed, micropolished, perfect. Guaranteed or your money back-$1000
-2.4/2.7L Crankshaft, 6-bolt 70.4mm, Std/Std, Excellent. Guaranteed or your money back -$ee auction below
-2.4/2.7L Rods, set of 6, rebuilt by Ollie's Machine Service-$ee auction below
-2.0L Rods, set of 6, used but good-$100
-3.2L Rods, set of 6, used but good-$125
Intermediate shafts, nice '70-89 style-$45 each
Pistons and Cylinders
-84mm Biral cylinders, set of 6, for 85mm bore, PERFECT fins-$325
-80mm 2.0L '65-67 Pistons, individuals-$10 each
-98mm 3.4L Mahle Ruf “Yellowbird” 7.5:1 Pistons and Cylinders, used, not inspected yet-$750
Cylinder Heads
-’73 2.7 Carrera RS specification Heads, 36/36mm Ports, 46/40mm valves, chamfered for 90mm/92mm cylinders, MFI injector hole, completely rebuilt (all work done by Ollie's Machine Service on a good set of '73 911T heads) including valve job-$1450
-1984 3.2L Carrera Heads, set of 6, 40/38mm ports, 49/41.5mm valves (stock), perfect original used condition-$550
Camshafts and Cam Housings
-3B Cam towers, pair, cleaned and spray bars R&R'd, ready to use-$190
-3.0/3.2 Cams, pair-$100
Fan and Housing
-2.0L Sandcast Aluminum Fan Housing & Fan, 245mm, very nice condition, rare; for ’65-68 cars-$400
Bosch Mechanical Fuel Injection parts (MFI)
-2.4L 911T MFI Stacks & Throttle Bodies, good for rebuild, w/ linkages-$225
-2.2L 911E Throttle Bodies & Stacks, w/ linkages, good cond.-$600
-2.2L 911E 010 MFI Pump, nice-$425
-2.4L 911S 013 MFI Pump, Freshly rebuilt by Gus Pfister of Pacific Fuel Injection, has *NOT* been installed since rebuild-$2,300
-Used pulleys, pump mounts, some linkage pieces and misc.
Miscellaneous
-Early muffler, for sport muffler conversion, missing left tail pipe, 2-in, $120
-Upper Magnesium Valve Covers-$75/pair
-Lower 2.0 Sand cast Finned Aluminum Valve Covers, perfect, dirty-$75/pair
-Engine Oil Cooler, threaded fitting, '65-71-$100
-'70-71 911 Clutch Disc, got some life left $30
-Cast Iron '70-86 Pressure Plate, usable -$70
-Crank Pulleys, various (many years), $40 each
-Sheetmetal, cylinder tin, etc., all years '65-89! let me know what you need-$100+ order
-Repro orange bar crest, new-$40
-3.2 Flywheel--for 915 Transmission, plenty of material left for a couple resurfaces-$120
-911SC Flywheel, plenty of material left-$120
-'82 3.0 U.S. CIS System, complete, was nice working, looks nice $400
-3.2L DME Unit, from 1984 car, Bosch #0 261 200 050-$300
3.2 Distributor, nice used stock dist.-$175
Suspension Parts
-930 Left side rear trailing arm, nice, bare-$600
Transmission Parts
-915 Gears, 1-5 & R, '72-73 -$175 each/$450 for all gearsets
-901 Gears, A, F, GA, O, V, ZA are available -$175 each, possible quantity discount
Oil Pumps
-3.2L Carrera Oil Pump, used but looks good-$250
I will take any reasonable offer for this stuff. Post on this thread or send me an email.
Scott Kinder
YTNUKLR@aol.com
