Results 1 to 7 of 7
Thread: 1971 S F/R Sway Bar Size???
    Senior Member sam71TargaS's Avatar
    Aug 2006
    Colorado
    What is the factory size for the front and rear sway bars on my 71 S Targa? I need to order bushing sets and need to get the proper size...
    Sam
    You are always best to measure sway bars to make sure you get the correct sizes, but they should be 16mm at the rear and 16m at the front. Having said that I have found some cars with 15mm front bars.
    Mike's right... you should always measure'm to make sure
    Use calipers for the rear (the diameter is consistent through the whole bar) ... And the fronts were usually stamped with the size on the face of the end (square) which you can see as it comes through the parallel that connects to the drop link...
    I would bet on 15 front and rear...
    Hope this helps,
    Cheers,
    My current 70S and my old 71S both had 15mm front and rear.
    Alan
    Aug 2006
    Colorado
    Thanks everyone for the help - much appreciated.
    Sam
    had the original bushings changed on my 70E with S options and the sway bars were 15 on both ends
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    If you don't have a caliper just use an open end wrench to determine the size of your anti-sway bars. Try a 15MM. If it fits, fine. If not try a 16MM. A few trial and errors will give you the size you have.
    Also...if you have the bars off the car, check both ends. One end has the size stamped on it. Usually a little wire brushing will reveal the stamped number.
    Rich.
  1. Replies: 8
    Last Post: 01-07-2017, 05:36 AM
  2. Correct size of rear stabilizer/sway bar?
    By npvpositive in forum General Info
    Last Post: 06-04-2013, 01:47 PM
  3. What size are these steelies?
    By garrege in forum General Info
    Last Post: 08-03-2007, 08:34 PM
  4. What Size Speaker?
    By creator8 in forum Technical Info
    Last Post: 12-06-2005, 09:51 AM
  5. What size ?
    By Chuck Miller in forum Technical Info
    Last Post: 05-18-2004, 09:25 AM
