Results 1 to 10 of 13
Thread: Value of 7 x 15 RS fuchs
    I just picked up a pair of 7 x 15 fuchs, these are different from past 7 x 15 I have owned, they have silver paddles and part # ends in 11 instead fo 41. The date stamp is 10/73 so I would assume these came off a RS. Anyone know value of these I also have the matching front 15 x 6's.
    Phil
    Jan 2003
    UK
    Sorry but these are later wheels which accept the 'ring' type centre caps.
    The 7" Fuchs that were used on the RS are part number:
    911.361.020.01
    - they accept the 3-pronged centre caps.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Andy,
    Is the only difference the between the 11 and the 42 part # number color of spokes.
    Phil
    .. these are later wheels which accept the 'ring' type centre caps.
    The 7" Fuchs that were used on the RS .. accept the 3-pronged centre caps.
    Andy,
    Does this (3-pronged c.c.) apply for the 8" as well?
    Richard
    Jan 2003
    UK
    Phil - 911.360.020.42 is an 8x15" Fuchs wheel
    Richard:
    As far as part numbers go, from memory of the 7's & 8's I've had
    01 is a 7" wheel which takes the 3-pronged centre cap (as used on '73 RS)
    11 is a 7" wheel (in early finish) which takes the 'ring' type centre cap
    41 is a 7" wheel as '11' above but with painted centre
    02 is a 8" wheel which takes the 3-pronged centre cap (as used on '73 RS)
    12 is a 8" wheel (in early finish) which takes the 'ring' type centre cap
    42 is a 8" wheel as '12' above but with painted centre
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Conclusion: "only the .01 and .02 are correct RS wheels"?
    Richard
    Jan 2003
    UK
    No - don't forget that the early 2.7RS were equipped with 6&7 x 15" Fuchs.
    6x15" part number is:
    911.360.020.00 - which accepts the 3-pronged centre cap
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Andy,
    Thanks for all the information. These must of come off a 74 Carrera.
    Phil
    May 2005
    Oroville, CA
    Phil, to add to the confusion:
    The forging number was not always the number that you used to order.
    Each of these had a different order number.
    911 361 020 01 & 02 came in three finishes:
    RSR spokes dipped black (early race dept. on STs & 914GTs etc)
    anodize spokes dipped black
    unpainted (for color to match)
    The forging number refers to three prong cap (lug centric) and replaced by:
    911 361 020 11 & 12 came in five finishes:
    anodize spokes two stage outer dipped black (like 74 Carrera)
    black center two stage outer (like 75 Carrera)
    unpainted (for color to match) two stage outer
    black center single stage anodize outer 77 & up ?
    unpainted (for color match) single stage outer 77 & up ?
    the forging number refers to ring cap (hub centric for 74-MY) and replaced by:
    911 361 020 41 & 42 came in two finishes
    black center
    they all are single finish on the outer like the 16s
    the 41 & 42 were later wheels (80s ?) and are usually thicker matieral as the car got heavier. Some late ones are 2mm thicker.
    The RSR 9s & 11s did not follow this logic as they were race only wheels. the 03 & 05 came with either cap hole depending on mfg. date. They were all RSR finish but also came unpainted for color to match. After 73 you usually got whatever she had in stock.
    confused yet?
    H
    Hi Phil, does your 7 x15 take a 3 prong or ring style cap. I have/had several sets of early *** 01 7x15s and a pair was dated 10/73.
    In case it helps other dates I have are 10/71, 6/72, and 3/73 all are 3 prong 7 x 15.
    Alan
  1. FS: Fuchs 9 x 15 brand new fuchs, other sizes soon
    By Alan.uk in forum For Sale: 911 Parts
    Last Post: 04-26-2020, 09:45 AM
  2. WTT: Set of early 15 X 6 Fuchs -- trade for set of 'flat' 15 X 6 Fuchs
    By Eminence Gris in forum Free, Trades, and Swaps
    Last Post: 03-03-2014, 05:52 AM
  3. WTB: set of 6x15 Fuchs "flat Fuchs" for 1973 model year
    By erick72pors in forum For Sale: 911 Parts
    Last Post: 09-10-2013, 08:02 PM
  4. Selling 6x15 fuchs, 3 pc Fuchs 8x17 & 11x17
    By cosley in forum For Sale: 911 Parts
    Last Post: 11-15-2010, 09:06 AM
  5. Trade: two 7x15 Fuchs for four 6x15 Fuchs
    By car-reras in forum For Sale: 911 Parts
    Last Post: 11-07-2005, 01:14 PM
