Results 1 to 10 of 10
Thread: Weight of 15x6 original minilites ?
    Hi
    I am looking at a set of 15x6 original minilites,
    were they all magnesium or were some aluminum ?
    these were powdercoated so its hard to tell,
    the only marking I can see on the back is B4 85M
    I only need the weight to figure out what material these are made from
    Thanks for your help
    I never weighed mine bare, but my (aluminium) 6.5 x 15 Minilite Sports weigh 40 pounds with a tire. Hope this helps...
    Brad Anderson
    911 1970 einspritzung Karmann coupe 0012
    Some kind of happiness is measured out in miles
    There is a cool article from Hemmings on the US Minilite site that might interest you...
    http://www.minilitewheels.com/pdf/Th...ne_Article.pdf
    The article mentions that Minilite switched to aluminum in 1973. On my wheels the date stamp is on the front, it reads '7 75 D', which represented 1975 production. My wheels also require mag lugs with washers, so I would guess that if your wheels take a more modern taper or ball seated lug, than they are aluminum.
    Brad Anderson
    Hi
    where were they marked on the front ?
    these are powdercoated and maybe that was covered up
    Dave
    Yep, on the front, 90 degrees from the MINILITE ENGLAND stamp. Actually, stamp is not accurate... the letters are raised in the casting, so even with powder coating I would think you could make them out. Check the lug seat though, I think that's the easiest indicator.
    Brad Anderson
    Jan 2003
    UK
    The style of the centre of the wheel is different between magnesium & aluminium versions.
    I would be very careful when/if buying original (35 + year old) magnesium Minilites if they've been powder-coated - it will be very difficult/impossible to gauge the condition of the magnesium...
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Goldmember ttweed's Avatar
    La Jolla, CA
    Quote Originally Posted by southbay356
    I only need the weight to figure out what material these are made from.
    I had a set of the original magnesium Minilites on my Formula Ford at one time. They were 13" x 5.5" and weighed 8.5 lbs. each. The aluminum ones weighed 12 lbs., so the mag wheels are almost 1/3 lighter. Extrapolate to 15" x 6" Porsche wheel size if you can....
    HTH,
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Quote Originally Posted by BAPhotowerks
    BAP,
    Do you need spacers for the 6.5 Minilites on either the front or rear of your 70 911? What size tires are you running?
    A Mg mahle gasburner weighs about 9.5 lbs FWIW.
    Phil
    They are 205/55 and there is no rubbing front or rear, and another no on the spacers.
    Brad Anderson
  1. WTB: Fuchs 15x6 Deep Six w/heart, refurbished or perfect original condition.
    By Steinar Andersen in forum For Sale: 911 Parts
    Last Post: 02-10-2013, 11:33 AM
  2. Replies: 0
    Last Post: 01-29-2013, 10:02 PM
  3. Minilites, 4, 15X6 With Lugs
    By Rennman in forum For Sale: 911 Parts
    Last Post: 04-05-2011, 10:19 AM
  4. value of minilites
    By 356robo in forum For Sale: 911 Parts
    Last Post: 06-19-2007, 03:54 PM
