Over the last six months or so, Hayden Burvill and his troops at Wevo have been working to assemble and create what has turned out to be one of the most incredible 911's I have had the chance to drive. The initial inspiration came from Ian Fitz-Simon who provided the donor car and many of the parts. The assembly and spirit of the car, however was done by Hayden's group. Test runs have been to Mexico with Dave Bouzaglou and the Pines to Palms run - about 2500 miles. Reading the new Excellence with its article on Jeff Smith's '3.7' conversion, I was prompted to share Hayden's spec sheet of the car as currently configured. The car is now being color sanded, the color of the repro minilites adjusted, and other details fine tuned. Hopefully the specs will add to the body of information for those considering a 'big block' conversion. Windrush/Wevo is amazing.
Build specification
Built for Steven Harris at Windrush Evolutions Inc. San Carlos, CA and first delivered on October 18th 2006
House Project C06-003
1973 911T non-sunroof Coupe
Chassis # 9113100493
Color – Tangerine
All steel bodywork with RS rear fender flares
Customized 911T front bumper with wide Deco strip and no over-riders, all holes faired and fog light holes trimmed for oil cooler openings.
Customized hood with vintage Road Race Style through-the-hood fuel filler cap
Customized LF fender with fuel filler door removed and faired
RS Touring style rear bumper
All Porsche and model badging removed
Engine
1997 Euro 3.6 Vario Ram motor – stock internals Type # M64/21
Engine # 63 V06351
Custom WEVO Engine dress-up kit in Black
WEVO 3.6 single pulley conversion – O.E. cooling fan speed
WEVO custom heater air supply conversion
WEVO power steering block-off
WEVO LH cam cover plate
SRP 3.6 amber fiberglass “engine tin”
3.2 Engine mount console
WEVO custom coil relocation
Patrick MS 3.6 conversion engine electrical loom
Patrick MS 3.6 / 915 lightweight steel flywheel
Rothsports custom “no-cable” 3.6 throttle linkage
WEVO SS Engine mounts
Exhaust
Rothsports custom 3.6 stainless steel headers with heater boxes
Rothsports custom 3.6 twin center outlet stainless steel muffler
Oil System
3.2 Carrera oil tank in stock ’73 location
Twin oil filters in stock locations – one on oil tank, one on motor console
SC style thermostat and hard-lines on RH rocker panel
WEVO custom twin front oil coolers – one in each fender
WEVO custom oil cooler fans on auto-thermal switches – one per cooler
Mobil 1 15w – 50w full synthetic oil
Fuel System
3.2 Carrera fuel tank customized with center fill spout for through-the-hood gas cap
3.6 Carrera fuel pump mounted on front suspension cross member
All late model fuel hoses through center tunnel
Engine bay mounted 3.6 style fuel filter
WEVO Custom engine bay fuel delivery hose
Transmission
915/61 Magnesium transmission
8:31 Crownwheel and Pinion ratio
Gear ratios 11/35, 18/33, 23/29, 26/26, 38/30
ZF Limited Slip Differential – built 80% configuration with 20ft/lbs static torque
WEVO XT_100 billet side cover
WEVO XT_032 bearing retainer plate
WEVO GateShift kit
Electronic speedo
WEVO SS Engine mounts for transmission.
Swepco 210 transmission oil
Rear Suspension
Customized Aluminum banana arms with fabricated trailing 930 caliper lugs
SC drive shafts
Bilstein gas pressure HD dampers
WEVO SPS full bearing spring plates
Sanders 28mm Ø torsion bars
SRP inner monoball cartridges
SRP 23mm Ø adjustable Rear Anti Roll bar
WEVO RARB consoles
TRE tie-down loops
65mm wheel studs
Front Suspension
Stock 1973 FLCA (front lower control arm)
Sanders 22mm Ø torsion bars
RSR front struts with RSR standard spindle height – no coil springs
Bilstein custom front damper inserts
WEVO CamberKing strut mounts & brace
O.E. turbo tie rod ends
SRP adjustable 23mm Ø Front Anti Roll Bar
Plastic suspension bushes
65mm wheel studs
Brakes
1978 930 Brake caliper configuration
Floating front rotors
23mm Ø master cylinder
Castrol SRF high performance brake fluid
Controls
MOMO Prototipo steering wheel
WEVO Classic 915 Shifter
WEVO R-Lite shift knob – black
Interior
Driver’s seat – Pete Z “Vintage Seats” model ST in black basket weave vinyl on Recaro slider
Passenger’s seat – Pete Z “Vintage Seats” model RS in black basket weave vinyl on Recaro slider
Custom WEVO RS style interior featuring Autobahn International RS carpet kit
No vent – No speaker grille 1976 dashboard
Radio delete
Custom Roll hoop
Instruments
10,000 rpm tachometer
150 mph electronic speedo
3 stock 1973 911 gauges
Electrical
WEVO Lightweight battery box
WestCo Miata 27 AmpHr AGM battery
Custom 3.6 ECU mounting under driver’s seat
WEVO custom wiring for all 3.6 conversion ancillaries
Lighting
H1 Headlights
Body Trim / Glazing
Silver window frames
Opening rear quarter light windows
Standard light tint side glass
No-demist rear window glass
O.E. tint top laminated windscreen
Wheels / Tires
Front wheels – Fuchs 15 x 7 - std offset
Rear Wheels – Team III Minilite style 15 x 9 – WEVO Custom offset.
Front tire – Michelin 180-60-15 DOT legal vintage racing “look” tire
Rear tire – Michelin 230-62-15 DOT legal vintage racing “look” tire
Steel O.E. wheel nuts
