Results 1 to 8 of 8
Thread: Checking CD box?
    Checking CD box?
    I have had coil issues recently and now I'm concerned about the CD box. It is the original CD in my 71 T, is here a way to check it? Do they wear out? Do they just quit working (like my silver replacement coil did)?
    Any help or advice is appreciated. Also posted on Pelican.
    They do just stop working. Sometimes when they get hot, sometimes they just stop altogether. They can be tested by wizzkids, or easily by trying it on another car.
    Apr 2003
    Portland, OR
    Is it a Bosch or a Permatune box?
    When my Permatune box started to go, it would get very hot and then cut out. An application of an ice cube or two would bring it back to life for a while.
    Finally replaced it with a used Bosch. From what I gather, the Bosch boxes can be rebuilt when they die. There are several suppleirs of rebuilt boxes if you send them a core.
    Harry
    Member #789
    2009 MB C300
    Bosch CDI
    The boxes CAN cause coil damage. I KNOW, believe me. The silver replacement Bosch coils SUCK. Make sure you're using an orginal, GERMAN MADE BLACK COIL.
    If I understand your question correctly: YES, the DO 'wear out.' It is NOT a case of either working or not; it can work, but still be defective - the first sign would be irregularities at higher rpm. Get RID of all silver coils. And find a good, used replacement CD box. Should solve you problem.
    Bahia Red '72 911S
    Meerblau PTS 2019 Speedster
    ES #333
    Quote Originally Posted by 69Sman
    Good point well made - my RS chewed a CD box after a silver coil was fitted - managed to get one of the black ones and she's running like a dream now.
    Shame a $100 coil managed to take a $1,000 CDi box
    Philip
    1973 911 Carrera RS #496
    Early 911S Registry #1808
    Loren at Systems Consulting can fix C.D. boxes. He's done a Delta Mark 10 for me as well. Good guy who understands electronics VERY well.
    Here's the information: http://www.systemsc.com/
    Good luck,
    Tom
    Early S Registry #235
    rgruppe #111
    Apr 2003
    Portland, OR
    I have heard that you can use a MSD High Vibration Coil in place of the black Bosch Coil with no ill effects. Of course you will need to remove the obnoxious MDS Label....
    Harry
    Member #789
    2009 MB C300
    Thanks for the replies. I spent the day cleaning all the connections, coil, dist, wires, CD box, etc. as per Warren Hall's reply on the Pelican site. I reinstalled the original black coil (now 36 years old) and it is working fine right now. I still have some fine tuning to do with timing and the carbs but it's running much better. I did buy the MSD coil as the research I have done suggests this is a viable replacement for the original black bosch coil, it will now be carried in the trunk, just in case...
    Oh by the way, I have been a registered user since Nov.05, but I just payed my dues in Dec. 06. Now a member of Early S, #1056
    Thanks again, Neal.
    P.S. If it was not clear in my original post, the CD box had not failed, I was just concerned about a failure since it is 36 Y.O.
  1. Checking valve timing on 69E
    By Djthom in forum Technical Info
    Last Post: 11-06-2013, 08:31 AM
  2. Checking for Value: 64/65 Date Coded Heads
    By 50/50 in forum General Info
    Last Post: 01-29-2013, 06:08 PM
  3. New forum member checking in!
    By ILovemy911 in forum General Info
    Last Post: 09-22-2010, 07:53 AM
  4. Checking Availability: Factory RS bumper corners
    Last Post: 01-20-2010, 10:55 AM
  5. '68 torsion adjustment - double checking :D
    By Fritter in forum General Info
    Last Post: 06-03-2009, 05:55 PM
