Results 1 to 2 of 2
Thread: ? Correct part # for genuine RS steering wheel
    Trying to put to rest all those "original" 73 RS steering wheels.
    Isn't the correct #, per the original parts catalog 914-347-806-10.
    Any input
    Careful, the numbers do vary on the same style of wheel. You need to be able to identify a 380mm foam core, leather wrapped wheel with the correct hub. The number stamped on the wheel itself is meaningless, and does not always, as do most parts with numbers stamped or cast match the factory parts manual.
  1. stock steering wheel part or custom?
    By mepstein in forum Technical Info
    Last Post: 11-17-2013, 05:05 AM
  2. Steering wheel part numbers
    By BOYER73S in forum Technical Info
    Last Post: 06-25-2011, 12:47 AM
  3. Steering Wheel Part No. 914.347.803.10
    By Bantam in forum General Info
    Last Post: 10-14-2008, 10:48 AM
