A guy here in Germany has a few of the middle sections in aluminium, where the number plate goes for the 65-73 cars. They are new. Is this an interesting item to go for and what is it worth?
Michael
Michael
Michael Moenstermann
Osnabrueck - Germany
Early 911S member #1052
'While accelerating the tears of emotion have to flow off horizontally to the ears.'
'Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer'.
'You can't treat a car like a human being - a car needs love'. (all Walter Röhrl)
Michael,
Restoration Design sells repros @ $90-95.
There were a bunch of poorly formed repros on ebay about 2 years ago that went for $70 to $100. Look at the openings punched at the top if they have the same dimension from the top edge they are the better ones. The poor ones were off by almost a half inch (12mm) lower on the right side than the left. So when first mounted they look way off from level.
The steel panel weighs 5.3lbs the aluminum is 1.8 Lbs.
Bob
Early S Reg #370
Are the restoration design ones good enough to pass for original? How do you get a hold of Restoration Design? Thanks, -Scott
I bought one from Parts Heaven. Watch the top tabs. They can come off pretty easily as they are or were glued. Not a big deal.
Tom
Early S Registry #235
rgruppe #111
P287A, Rear license panel, aluminum 1970 - 72 911S, 89.95
www. Restoration-design.com
Fax 517 663-5813 Ph 517 663-4545
they are in Eaton Rapids, Michigan. They do their own stamping and typically don't answer the phones when the big presses are pounding away so the fax is a better way to get to them.
Bob
Early S Reg #370
I have bought one and will report on the quality when I get it, but due to the weak Dollar it will be too expensive I guess.
Michael
