Results 1 to 10 of 20
Thread: Tire Recommendation
    Tire Recommendation (Pics)
    Ok - my Fuchs (Flat 6x15) are at Al Reed's and I need a tire recommendation. The car is a survivor and I'm keeping it that way. Fuchs will be restored to original. I am currently running Yokohama AVS 195/60's. I do not track this car. Is there a good tire that will wear a little longer than the Yokos and look a little more period correct? I saw an early car with Michelin Pilots (I think 205-60's) that looked good.
    I have attached a photo of a car whose tire I like - any ideas?
    Here's a crummy photo of the car in question:
    You can still get the original Michellin/Dunlop/Pirelli tires in the correct 185/70 size if you want. They are all pretty expensive, pushing 300 or more ea. I went with the Vredesten that is the correct 185/70 OE size/tread type but not so expensive, maybe 90 ea.
    think closest modern size tire is the 15 195/60. you can search the thread and find lots of discussion on this
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Michelin 185/70 XWX
    www.cokertire.com
    The Michelin XWX 185/70 - 15 is period correct and probably best looking tire you could use for a gennie look. Still made in France and so not cheap at $301 each.
    I guess what I am really looking for is a modern that doesn't look as racey as the Yokos.
    Can anyone make a guess about the tire in the first photo?
    Oct 2005
    Minneapolis, MN
    I like to use 195/65-15........I think they look "right".
    Just my opinion....
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
    Quote Originally Posted by Flat Six, inc.
    Just my opinion....
    What brand and tire?
    The tire in the photo does look like Michelin to me. I've had Michelins that had treads that looked identical, but not on a Porsche.
    Paul Schooley
    S Reg #863
    R Gruppe #330
    daepp...
    here is a good site for tire size info
    http://www.356registry.org/Tech/tires.html
    john
    Here is a chart to compare sidewall heights:
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. Tire recommendation
    By coma in forum Technical Info
    Last Post: 12-22-2011, 10:54 AM
  2. Tire recommendation
    By Max (SD) in forum General Info
    Last Post: 02-23-2010, 08:12 AM
  3. Tire recommendation
    By EA911 in forum Technical Info
    Last Post: 06-11-2009, 09:39 PM
  4. Tire Recommendation
    By Chuck Miller in forum General Info
    Last Post: 07-09-2006, 07:37 AM
  5. Tire Recommendation for 69S
    By Mike Baum in forum Technical Info
    Last Post: 10-04-2003, 05:31 PM
