Results 1 to 10 of 14
Thread: Tool bag '73
    The Netherlands
    Tool bag '73
    Hi,
    Could someone post a few pics of a 911 '73 tool kit bag, in,- and outside please? I believe I have the wrong one...
    Cees
    Cees,
    At first glance it looks just like my April build '73...
    Hope this helps,
    Cheers,
    The Netherlands
    toolkit bag
    Thanks Chuck,
    My RS is a May '73 build so may be it is correct after all according to you. That would be great but I hope someone else can confirm...Robert?
    Cees
    Sent you an email with details Cees. I'm sure there's been lots of past info on this subject. Included pictures of an Original 73' toolkit with snaps. There was a mix of kits with straps and a few early production cars with buckles.
    Best, Robert.
    [SIGPIC][/SIGPIC]Robert D. Groß
    and a few more pic's
    My 73.5 T toolkit is the same, but without snaps. I think that there was a string to tie it with, sewn on along one side. The string is long gone, however.
    Tom F.
    Long Beach, CA
    Nov 2002
    Worshington State
    Mine has opposing pockets with seperate red handled philips and flat-headish screw drivers. What is the one with a skinny blade at the end of the standard blade used for? (Yes, I am no Porsche mechanic)
    Seattle WA
    I've heard 2 stories (that I can remember) on the skinny headed straight blade... both in reference to 356's, as that's when that style of blade first came out. 1) for use on the small screw that holds the "points" down in the distributor and 2) to pop the hubcaps off.
    Don't know if either one is the real reason, but it sounded good enough to post
    Sounds interesting... I allways thought the long flat was used on the 911 for the 6 air correction screws on the manifolds or adjustment screws on carbs?
    Robert..
    Quote Originally Posted by RickS
    I believe that the flat blade is to secure the generator/fan pulley on 356/912 motors when changing the fan belt. You should see a notch in the forward pulley half for this. The blade fits in the notch, and stops against one of the generator housing screws.
    So, the blade probably has no use to a 911 owner, but that doesn't seem to stop some of us from paying loads for this special tool!
    Also, the toolkit for a sunroof coupe should also include an emergency sunroof handle.
    Tom F.
    Long Beach, CA
  1. FS: Late 'JUSIN' Tool Bag for TOOL KIT
    By METAVINYL in forum For Sale: 911 Parts
    Last Post: 12-21-2013, 01:34 PM
  2. Replies: 3
    Last Post: 10-17-2013, 12:11 PM
  3. FS: KLEIN 21 Spark Plug Tool w/ Allen Key LWB Tool Kit
    Last Post: 09-27-2013, 04:18 PM
  4. WTB: Sunroof tool for a '69 Tool Kit
    By s2guy in forum For Sale: 911 Parts
    Last Post: 01-07-2009, 07:49 AM
  5. Cool tool... mapping tool that is.
    By Jens in forum General Info
    Last Post: 06-11-2007, 02:46 PM
