Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Hood Prop Ideas
    Jun 2003
    Bend, Oregon
    Hood Prop Ideas
    My '67 SWB has hood mounted Cibies and as a result the hood shocks are inadequate to hold up the hood. I'd like to install a hood prop and would like it to be simple and cool and with no holes drilled in the hood.
    Any ideas?
    Even better, does anyone have a source for stronger struts? I know they were an option when the Cibies were installed by the factory. I'd have to assume that some other OEM strut could do the trick.
    I am getting sick of using my squeegee as a prop.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    John,
    I don't like gas struts because they always wear out after a year despite the claims of the manufacturers. Also, big struts will cause a water leak at the trailing edge of the trunk lid.
    The most elegant solution I've seen came on the 964 cup cars-- it was a piece of aluminum rod attached about halfway down the inside trunklid on the starboard side of the car that swung out and had the end sharpened so it could fit inside the cup for the monoball. There was also a spring steel clip toward the rear of the hood so when it was not in use, it could be clipped to the hood.
    I wonder if someone with a 964 cup could post a picture of the hood prop, it was the best, lightest and strongest solution i've seen.
    I found a 20 foot shot. This is, obviously, a 993 cup and it's on the other side but you get the idea. Photo credit www.cupcar.net
    Hello
    lightweight '73 rs's and also the 964 RS have an aluminium "pin" (I dont know the exact name in english) to hold up the hood. It is a genuine porsche part and still available new from porsche.
    K.
    ok, while I was searching for a picture that I did not find, 304065 came up with the same item. This part is still available at porsche and not that expensive. I have one lying somewhere in my garage, but have not used it yet, since my shocks are still doing a great job :-)
    i've got the 964RS setup and its great. its also very intuitive for other people propping the hood. you will need to drill a couple of holes though.
    another cool option is the carbon fibre prop from seine systems
    http://www.seinesystems.com/Ult-Strut-Home.htm
    Cheers, Ryan
    Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
    What about the product our very own Sherwood offers? I have one and it works great but I don't have Cibies.
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    Quote Originally Posted by bob tilton
    Look up.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. Fs:tabot mirror,factory hood prop and aluminum dash parts
    By 71-911T in forum For Sale: 911 Parts
    Last Post: 01-05-2011, 10:09 AM
  2. Any Ideas...
    By vicrola in forum General Info
    Last Post: 02-28-2010, 05:12 PM
  3. I voted for Prop 911
    By Silverbullit in forum General Info
    Last Post: 11-10-2008, 10:34 AM
  4. Lighting ideas
    By jameshtaylor in forum Technical Info
    Last Post: 06-02-2008, 01:29 PM
  5. Car dolly any ideas???
    By 911quest in forum General Info
    Last Post: 09-08-2006, 09:44 PM
