Thread: Spindle nut trouble
    Spindle nut trouble
    Hi guys,
    Hoping someone might have some wisdom here. I've searched here and on PP finding no help. I'm buttoning up my front hubs after installing new bearings. I managed to lose one of the spindle nuts. I have the Koni struts and the spindles are 16mm. I ordered another nut from Stoddard. I've tried it on both spindles and it won't thread. However, the old nut with thread on both sides. I've had them ship me out a second nut with the same result. Are there different pitch threads for the 16mm nuts? If so, anyone know who sells both styles?
    Thanks in advance,
    T.
    '73.5T -- ST replica project
    Member #1045
    http://www.paragon-products.com/
    These guys are very knowledgeable with Koni products.
    I bet they can help you.
    1970 911S Targa
    On the road again soon.
    Just a little update on the spindle nut question. I haven't called Paragon yet, but I did have some further conversation with Stoddard. Paul, one of their resident experts seems to recall coming across this issue before. He's put in a question PCNA. Sounds like the Koni struts are NLA, therefore the only 16mm spindle nut corresponds to the 16mm nut for Boge/Bilstien struts. I'll update as I learn more.
    Member #1045
    Mar 2006
    Louisville KY
    I have a set off of a pair of SWB koni if they will work and your interested let me know.
  1. Replies: 4
    Last Post: 03-07-2014, 06:18 AM
  2. Bosch H4 Trouble
    By 71Coupe in forum Technical Info
    Last Post: 08-09-2010, 05:36 PM
  3. Broken Spindle - Driver Side
    By Neunelfer in forum Technical Info
    Last Post: 04-01-2009, 08:33 PM
  4. Bilstein strut spindle thread size issue
    By ret9191 in forum General Info
    Last Post: 09-06-2007, 05:54 PM
  5. O Man, I'm In Trouble Now !
    By John Fusco in forum General Info
    Last Post: 05-08-2006, 02:45 AM
