I have a full set of 6 Velocity stacks for Weber 40's
Gold Elox finish
Factory mesh domes.
Totally new - never fitted.
See pictures
What are they worth??
I can take PAYPAL if anyone wants to make me an offer.
Gold Elox finish
Factory mesh domes.
See pictures
i am interested. sent pm.
thx, --mike
DAMN, those are WICKED! Will they fit MFI? Where did you get them? Did you have them fabricated or???
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
Kenikh,
I got them in Germany.
Don't know if they will fit MFI
They are a bolt on for Weber 40 IDA/IDS/IDTP3C
I recognize the tea strainers, but the bases look anodized from spun aluminum horns with machined bases. Tea strainers those ain't!
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
Find a machine shop with a CNC mill. They should be able to knock them out in as many shapes and numbers as you wish. Any length, any diameter top to botttom.Originally Posted by kenikh
FWIW, a computer engineer I met a few weeks ago does his own CAD drawings which in turn he writes on disc in the correct machine code.
His last project was making his OWN window seal for a muscle car he was restoring. Nobody made it so he drew it and took the program to an operation that does weatherstripping and had them make in on their water cutter. He said the owner was a bit puzzled when he handed him the disc and told him "I need you to make this"...
Sleep on that.
Best,
Tom
Early S Registry #235
rgruppe #111
I talked about this option with Steve Weiner once. He suggested I experiment with a window screen in front of a box fan. They look cool, but cost power.
Tom F.
'67 911S Slate Gray
'92 964
#736
Hello; TWM makes all sorts of velocity stacks for anything you can think of. The screens are spun onto the stack with the collar piece. They are not good for keeping fine sand out though. Thanks Eric
They let in just a little too much "stuff"...
sure did look cool tho...
cheers
Thom Kuby
