Thread: Weld in new headlight bucket
    Is it possible to weld? in a new bucket for the headlight in the fronfender? If so who sells them? The old bucket has rusted thru at the point where one on the screws from the headlight is supposed to go thru/attach. The rest of the fender is fine.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Senior Member boba's Avatar
    Jul 2006
    DFW
    Yes, Restoration Design is one source. There are 3 versions: SWB, '69-'73, and '74 on. Ask me how I know. Not all reproductions are a correct fit. Again ask me how I know.
    Regards,
    Bob Aines
    Thanks Bob, I will try Restoration Design.
    Dec 2004
    For a bit of insurance
    After the new bucket is welded in, cleaned and primed, use a long handled brush with a small head to apply a even layer of seam sealer over the weld.
    The area around the headlight bucket collect a lot of road dirt. That dirt is like a sponge holding water against the metal.
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    When you take out the old headlight bucket look at how deep the fender flange holding the bucket is on the inside of the fender. Not much material to work with. Since the bucket is spot welded to this I decided not to damage this flange too much by drilling out the numerious spots. Instead, I used a thin rotary grinding disc, cut away the bucket, 1/2" back from the flange, and then carefully ground the spots off the remaining bucket only. Then with a small cold chisel, start popping the bucket off. If you did the grinding correctly, it should go quickly. Use a 3M soft abrasive disc on an air tool and clean off the flange to bare metal.
    Get the new bucket and polish off the area to contact the flange to bare metal as well. Instead of welding, I suggest using the 3M body panel epoxy. The bucket is not a structural part and the epoxy is used to hold quarter panels on with new cars. The finished product will look factory and you won't have to apply heat to the seasoned fender. Good luck Allan
    1974 914 2.0 Yellow/Black
    The epoxy tip is great Allan, thanks!
  1. NOS Hella Headlight Bucket
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 11-26-2012, 08:16 AM
  2. Internal b-post kidney.... To weld or not to weld?
    By Richsmith901 in forum Technical Info
    Last Post: 11-10-2012, 12:26 PM
  3. WTD: headlight bucket
    By typ901 in forum For Sale: 911 Parts
    Last Post: 11-19-2009, 11:50 AM
  4. headlight bucket replacement
    By robmog in forum Technical Info
    Last Post: 10-15-2009, 07:24 PM
  5. WTB: Headlight Bucket
    By joetiii in forum For Sale: 911 Parts
    Last Post: 11-19-2006, 05:07 AM
