Results 1 to 10 of 10
Thread: WTB; I need a "clip"
    The rear turn signal housing attaches to the body with two screws. For the screws to bite there has to be a "clip" on the metal lip that the screws go thru. I need one of these "clips".
    Can anybody sell me one or advice me where to get one?
    Best
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    John,
    I may offer you the advice of getting the Porsche PET disk that will allow you to search for part numbers on all items for your car.
    You can then call many vendors and just provide them the part number.
    Good luck with your project.
    Bob
    1970 911S Targa
    On the road again soon.
    Jun 2003
    Toronto
    Go to any car audio installation place, they will have thousands of them in the "back". Most aftermarket speakers come with them and they don't get used.
    Any good hardware store will have them too, usually stocked in pull out drawers near all the metric bits.
    Brad Anderson
    911 1970 einspritzung Karmann coupe 0012
    Some kind of happiness is measured out in miles
    Hi Bob
    I have the PET but I cant find it. I am not sure of the English name for it but could it be "U-nut"?
    EDIT; I found it, its called "klips nut lock" in the English PET. I had to do a search for "nut" and there was a lot, and of course the nut I was looking for was one of the last hits in the search ! I almost went nuts
    Anyone have one of these?
    I probably have one, but I'm traveling, if you haven't found one by Thursday next week, PM me and I'll look for it
    Henry
    Hey John, a side note, I don't have the reflector that you were seeking. I have a housing but no luck. I will look tonight for the clip.
    Rick
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    Thanks Rick !
    Hey John, PM me with your info again and I'll get it out to you. Just need the one?
    Rick
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    Clip
    Hi John,
    if you get stuck I can find you a couple, I'm breaking a 71 Coupe, it still has its lights installed
    Ian
    Anouska's Daddy 1995-2005 Now and Forevermore
  1. WTB: 4 OEM "Ring Clip" Fuchs Center Caps in stock matte anodized finish.
    By MountainRoads in forum For Sale: 911 Parts
    Last Post: 04-18-2013, 07:28 AM
  2. "911Reborn The Clip (with subtitels)"
    By serie1926 in forum General Info
    Last Post: 08-23-2012, 05:47 AM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 03-09-2012, 07:53 PM
  4. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-03-2012, 08:51 AM
  5. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 01-24-2012, 01:59 PM
