Is it possible?
followed by...
Will this combo fit on the rear of standard body car with
flat (20mm+) offset 7 wheel
or is 7R wheel (40mm+) offset required?
Is it possible?
followed by...
My first season of DE saw me use 185/70/15 Yoko A008R's on std. Fuchs 6's (front) and std. Fuchs 7's (rear). No issues at all, well, except for the driver.
Jim Richards
Aubergine 1973 911E Sunroof Coupe w/ 2.7RS MFI
Early 911S Registry Member #589
GruppeB #911
Tom & Jim,
Thanks for quick responses - frankly I'm suprised..
I didn't think it was do-able
Any chance of a picture or two.
Also as a follow up - what wheel / tyre combo do you think this is?
Here ya go...
Jim Richards
GruppeB #911
When I was tracking my stock bodied 911E at Streets of Willow, I ran 205/50 Toyo RA1's on 15x7 Cookie Cutters.
Sandy Isaac
'69 911E
#543
Chris that car is 911R #19 owned by registry member Frank Gallogly.
Wheels are deep six (front) & 7R (rear) with 185/70 x 15" Michelin X all round.
Andy
Early 911S Reg #753
R Gruppe #105
As mentioned, it works fine. But, it is 'stretching' the 70's a bit - they're really intended for 6's. I ran them on these 7" AR's all around (same offset as standard 7" Fuchs). This is the only photo I can find that sort of shows how they sit within the fenders:
Stretching the 70's? My tire guy races early 911's and he convinced me to go this way a few years back. They worked quite nicely at Summit Point, Mid-Ohio and Watkins Glen. And I'm not talking parade laps.
Jim Richards
GruppeB #911
The later 2.7 RS models came equipped with 7" & 8" x 15" Fuchs wheels with 185/70 & 215/60 tyres.
Andy
Early 911S Reg #753
R Gruppe #105
Yes, I said 'stretched'. Tire manufacturers' specify a wheel width of 4.5" to 6.0" for 185/70-15 tires since the tread width is only 5.5 inches (i.e., your 7" wheel is 1.5 inches wider than the tire's contact patch on the tarmac!). Again, they will work on 7's (I ran that combination last year) just looks a bit odd. 215/60-15 is the correct width & diameter for 7" wheels. Maybe this shows it better:
