Results 1 to 10 of 12
Thread: 4 piston brake caliper kits
    Feb 2005
    Lake Tapps, WA
    As of right now, I am just putting a feeler out there...
    I just put new brakes on my car and I absolutely love them and figured I would offer this to others on the list.
    On my ST, I had S calipers that were rebuilt using the SS pistons, new seals and new pads. I have never been happy with the stopping power especially considering I have a 3.2. So I set out looking for a 4 piston caliper that would bolt up without any hokey adapter kits, fit with 15" wheels and most importantly...look period correct. Well I found it. These calipers are brand new and they met all of my criteria perfectly. I have done all the research on them, mounted them on two of my cars, know where to get all the necessary parts and consequently, it is a bolt on system that works perfectly.
    Soooo, I have the opportunity to purchase more of these calipers but I am probably limited to a dozen sets.
    I am looking at selling kits that are 100% ready to bolt on your car. The only thing needed would be brake fluid and rotors if you choose to replace them. These would be for the fronts only and by the way, I do use the larger 21mm Mercedes Benz master cylinder.
    The kit would include two NOS calipers, pads, stainless lines and any necessary hardware. I will also include photo instructions taken from my car.
    I am not committed to any of these but I think it is an awesome setup and was just wondering if there would be interest for a dozen sets. I am thinking the price would be in the neighborhood of $800 plus shipping for everything. You can spend that rebuilding a set of S calipers! Or worse yet, how much are turbo calipers now???
    Please give me some feedback.
    Thanks, Chris
    P.S. here is a photo of the install on my ST
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
    Senior Member e72phil's Avatar
    Feb 2004
    Melbourne,Australia
    Chris, what does "Everything " include ? Callipers, dogbones (are these needed ?) wheel spacers (I see thm on your pic).
    Do these use the std rotors and what struts must you have to mount the callipers ? later model ones with 3.5" bolt spacings ?
    Phil Lack
    Early 911-S Registry # 690
    R-Gruppe # 367
    Past President: Australian TYP901 Register Inc. # 0002
    2.0 '66 911R : sold
    2.0 '68 911S : sold
    2.4 '72 911E coupe original Aubergine
    2.4 '72 911E :sold
    2.4 '72 911T : sold
    3.6 '94 993 :sold
    3.6 '97 993 C2S :sold
    '01 Ferrari 360 sold
    '15 CLA250 Benz
    '12 BMW 1M coupe (OMG!)
    Feb 2005
    Lake Tapps, WA
    Sorry, I should have been more clear. Wheel spacers are not needed. I only use them to fill the fender out a bit more.
    You can use "S" rotors, "SC" rotors or Carrera rotors. I personally use the Carrera rotors but I did have to sand the pads just a bit to get them to fit but there were no clearance issues with the rotors.
    "Everything"... well this includes the calipers, pads and the Stainless braided brake lines. The hardware to retain the pads as well as all the brake line fittings associated with the caliper are also pre-assembled.
    I don't know what you mean about "dog bones"
    These calipers bolt directly to struts with a 3.5" bolt spacing
    I have these installed on 3 early cars now and everything works perfectly.
    '67 911S
    '69 911S
    '70 911ST
    '11 Spyder
    Feb 2004
    Melbourne,Australia
    thanks for the clarification. If the callipers bolt directly onto teh struts, tehn dogbones are not required. These are used when the bolt holes for the callipers are a different pitch than the strut or are a 90 degree rotation.
    Phil Lack
    R-Gruppe # 367
    2.0 '66 911R : sold
    2.0 '68 911S : sold
    2.4 '72 911E :sold
    2.4 '72 911T : sold
    3.6 '94 993 :sold
    '15 CLA250 Benz
    Feb 2005
    Lake Tapps, WA
    yes, these bolt directly to the strut using the factory bolts. Very simple installation...to tricks.
    '67 911S
    '69 911S
    '70 911ST
    '11 Spyder
    Chris,
    How large are the brake pads on these? How much bigger than S caliper pads?
    Brooke
    Brooke
    1969 911 ST w/ 2.8SS
    1973 911 RS tribute with 3.3 turbo
    1970 914-6 w/ 2.2S (sold)
    1972 BMW M2 (sold)
    R Gruppe #338
    S Reg # 855
    Feb 2005
    Lake Tapps, WA
    about twice the size.
    '67 911S
    '69 911S
    '70 911ST
    '11 Spyder
    Goldmember ttweed's Avatar
    La Jolla, CA
    Quote Originally Posted by endo911rs
    Where did you find a 21mm MC? I looked high and low for one of these a few years back and could not find them anywhere. AFAIK, only 23mm is available from Ate anymore, which is what I ended up using.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Feb 2005
    Lake Tapps, WA
    My appologies... I think you are correct about the 23mm master cylinder. Geese between master cylinders, torsion bars and sway bars, I get my Millimeters mixed up!
    '67 911S
    '69 911S
    '70 911ST
    '11 Spyder
    Feb 2003
    Los Angeles
    Weight
    Nice setup.
    How much do your calipers weigh compared to the S alum. calipers?
    Can you give us a photo of the brake pads compared to the S brake pads?
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
  1. Brake Cooling Kits Question
    By bxd in forum Technical Info
    Last Post: 12-19-2013, 08:49 AM
  2. FS: Brake Rebuild Kits
    By John912 in forum For Sale: 911 Parts
    Last Post: 09-28-2013, 03:40 AM
  3. Rear caliper piston alignment?
    Last Post: 02-22-2010, 07:54 PM
  4. FS: Caliper Rebuild Kits
    Last Post: 08-17-2009, 12:33 PM
  5. Brake piston orientation
    By robinfly in forum Technical Info
    Last Post: 11-05-2007, 06:15 PM
