Thread: Gas gage adjustment
    Gas gage adjustment
    When the gas gage on my72S drops just below 2/4 I am almost out of gas. I will run out before the gage reaches the ¼ mark. The reserve light is working correctly as it comes on just below 2/4. Is there any way to adjust the gage or sender so that it reads correctly?
    Steve
    72S src
    Registry# 909
    I have a problem with my gas gauge as well but it is the opposite reading. I burn 8 gallons and my gauge reads E. I was reading over on the pelican site that you can remove the sending unit and inspect the float to make sure it moves up and down smoothly. I think crude builds up and prevents the float from dropping completely. The slides can be cleaned w/ a solvent of some sort buit don't take my word as gospel.
    I'll be opening my tank up tommorrow to check it out. I don't think mine has this same issue but we'll see.
    Joe
    '69 E Targa "Roxie"
    Early S #937
    Nov 2002
    Worshington State
    Ayup, its not the gauge but the sender in the tank. You will need to pull the sender out and make sure that the float can easily travel up and down the wires with little or no resistance and that the nut on the bottom of the assembly is still afixed. Be very care on de/reinstall since the wires are very delicate. Removal and install is very simple.
  1. 1965 Porsche 912 ( painted 3 gage )
    By Vwbeck in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 04-18-2012, 02:21 PM
  2. 911 clutch adjustment
    By joetiii in forum Technical Info
    Last Post: 10-02-2008, 09:43 AM
  3. WTB: MFI Adjustment Screw NLA
    By jcarpio in forum For Sale: 911 Parts
    Last Post: 01-02-2008, 11:34 AM
  4. Sway Bar Adjustment
    By HarryD in forum Technical Info
    Last Post: 04-16-2003, 12:26 PM
