Thread: tubeless valve stem in deep 6 question
    what type of tubeless valve stem will fit deep 6s? the hole is longer on one side and regular stems can't get a grip. i suppose a tube would work, but there must be some way to go tubeless.
    Jan 2003
    UK
    I use TR415 valves in my deep sixes:
    Andy
    Early 911S Reg #753
    R Gruppe #105
    thanks, off to the tire store.
    Jun 2005
    Perth WA
    My guys used "Bobcat" valves, which seem to work!
    Michael
    Nov 2003
    Sydney
    Chaps,
    Maybe I am being over cautious but is it wise to run deep sixes without tubes even though I don't stress my Dunlops too much ?
    Cheers,
    Dennis.
    S Registry member 536
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    Dennis-
    It would be unwise to run your Dunlops WITH tubes. Modern tires are not intended to be used with tubes, so the tubes interfere with the tire's ability to disipate heat. Deep sizes lack the safety bead that is intended to keep tires on the wheels in the event of a rapid deflation. This really doesn't have anthing to do with tubes, but there is often the assumption that it does.
    -Scott
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
  1. Rubber valve stem, deep six?
    Last Post: 04-28-2023, 11:03 AM
  2. Valve stem help
    By surf in forum General Info
    Last Post: 05-14-2010, 04:08 PM
  3. valve stem for fuchs rim
    By vintage83 in forum Technical Info
    Last Post: 07-01-2008, 09:08 PM
  4. Valve stem holders??
    By Semjon in forum General Info
    Last Post: 01-06-2006, 08:35 PM
  5. Replies: 22
    Last Post: 08-28-2002, 07:37 AM
