Thread: Ground wire, rear taillight
    The ground wire for the rear right taillight is hanging under the bumper, where is it supposed to be bolted?
    On the left side it goes to a bolt on the engine tin just behind and to the right of the taillight housing. The right side is not a mirror of the leftside.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    I thought on both sides it is grounded via the bolts that hold the bumper to the chassis rail.
    I think grounding to the engine tin is incorrect.
    Bob
    1970 911S Targa
    On the road again soon.
    Any taillight grounds I have messed with have allways been grounded with the bumper to chaise bolts as Bob has already stated. Clean both side of the connactor and mating surface on the bracket and allen bolt as well. Other wise it won't take long for the ground to possably go bad. Of course thats up here in God's country where salt is used on the roads.
    Bill Barnich
    R Gruppe Nr.230
    Early S Nr.960
    71 911T/2.7 Tangarine
    73 911?/3.6 work in progress
  1. Ground Wire
    By mfitton in forum Technical Info
    Last Post: 10-04-2011, 07:49 PM
  2. replica cibies -ground wire issue
    By hoffman912 in forum Technical Info
    Last Post: 07-30-2010, 11:57 AM
  3. Why ground straps on a 73 rear deck lid?
    By caproader in forum Technical Info
    Last Post: 04-12-2010, 01:45 PM
  4. Horn button Ground wire
    By Davz912/911 in forum Technical Info
    Last Post: 10-16-2006, 07:22 AM
