Seat belts with diagonal shoulder strap, and inertia reels for SWB cars. These fit and work well, and offer a reasonable alternative to the hard to find, and some say, unsafe originals. Manufactured in '01. $250.
Tom F.
'67 911S Slate Gray
'92 964
#736
your PM box is full.
Hi
I am looking for some belts for my 71T.Where do the "hooks" on these belts fit? I am looking for belts that are attached to the sides of the seat rails like I belive the originals where. The short piece of your belts maybe look to be a bit long to be attached to the inside of the seat, and the buckle will be to long to be in the middle of the lap?
Early 911S Registry #931
1971 911 2.2T Coupe Tangerine
Tom...
Have you installed these in a SWB that does not have the bolt hole on upright post...
John,Originally Posted by Zithlord
As best I recall, the hooks are anchored to eyebolts located in front of the rear seats. The position is very low and not very effective in paasenger restraint.
Harry
Member #789
2009 MB C300
Cleaned out the box. It's a SWB thing, you need the belts that attach to the seats.Originally Posted by Zithlord
Tom F.
'67 911S Slate Gray
'92 964
#736
John, These were in my '67 with the inertia reels bolted in the factory holes under the rear quarter windows.Originally Posted by johnhora
Tom F.
'67 911S Slate Gray
'92 964
#736
Thanks Tom and Harry...
I was wondering if there had been a true 3 point belt system for the swb cars...
pm sent
thanks
Looking at the PET (https://techinfo.porsche.com/techinf...1_KATALOG.pdf), it looks like three pointers showed up in '68 as a factory optionOriginally Posted by johnhora
Harry
Member #789
2009 MB C300
My 68 came with 3 point belts from the factory, they are attached to the bolts under the quarter windows
Henry
