Results 1 to 8 of 8
Thread: WTB: '69/70/71 Hard Oil Lines
    Hi,
    I am looking to buy the hard oil lines that go inside the rocker.
    Thanks for your help,
    --mike
    Check a junkyard that has a car that can be cut up. Or, you could make your own.
    Tom
    Early S Registry #235
    rgruppe #111
    Tom,
    I think you are right about making your own. It is most likely my best bet.
    --mike
    I have a set off my '75 Carrera. Not sure how they differ from year to year.
    Harold #334
    I believe/think that they are a larger diameter and run external (outside the rocker). I am not 100% sure!
    Harold,
    The lines are different and were run internally through the rockers for those years...
    However, what you have (and maybe are willing to sell) is the start of a very practical up-grade.
    The factory was sneaking up on the best location for the exterior oil cooler thermostat placement from the time they put one of these on (probably in '67/'68) all the way to '73. With almost every year changing the location with a more impractical one.... hung out by the exhaust, hung in the engine compartment... etc. etc. With the 'new' G- series chassis in '74 they figured that placing the thermostat, out of harms and heats way, just ahead of the rear wheel was the best option........ duh !!!!
    Coupling your 'late' hard lines and thermostat with an 'early' radiator type '69-'72 external cooler ... you have a wonderfully efficient cooling system for an early car ............. but not period correct...
    I've had this system on my car for over 15 years ........
    69S hard lines
    I have a set of through the rocker hard lines from a 69S. I would take $500 for them. Please respond to jjmohler@msn.com
    Chuck, thanks for the info. Yes, they are for sale.
    http://there.dino.com/harold/index.cgi?page=oillines
    thanks,
    Harold
  1. Hard fuel lines in a '69E
    By rdelmendo in forum Technical Info
    Last Post: 12-31-2013, 03:40 AM
  2. FS: restored MFI hard lines
    By 911scfanatic in forum For Sale: 911 Parts
    Last Post: 03-14-2013, 05:40 AM
  3. PRE-74 Elephant Racing Oil Lines - Rocker Hard Lines to Cooler
    Last Post: 11-07-2012, 10:58 AM
  4. 2 NOS hard oil lines
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 12-13-2009, 06:03 AM
  5. WTB 73 Hard Oil Lines
    By rick2 in forum For Sale: 911 Parts
    Last Post: 08-03-2005, 05:38 AM
