Thread: Early headlight adjuster grommet?
    Jan 2007
    North of the GG Bridge
    On the early SB19 SB 20 SB 21 USA headlight assembles, the adjusting screws have a threaded tang that fit into a grommet providing the adjustment connection. The grommets are deteriorating on my assemblies so the tang pops out and they will not hold an adjustment.
    Is there a part number for the grommets, are they being reproduced or is there a common workaround for replacing them? Perhaps a small rubber stopper could be modified to work. Can someone point me in the right direction, I would appreciate it.
    I used a small cross section piece of hose....the hose was about the same size...may have been vacuum hose....it has worked fine so far...
    Goldmember ttweed's Avatar
    La Jolla, CA
    Quote Originally Posted by johnhora
    Ditto-I have used Tygon tubing for that, which comes in a range of sizes, but I can't remember what size fits there. 1/8" maybe? Take the whole assembly down to the local hardware store and just test fit the various tubing sizes until you find the one that is a good, tight press fit in the hole.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Jan 2007
    Thank you for the responses the tubing worked out great. I got 2 varieties, both 1/8” one was a fuel and the other was a vacuum. The fuel was a thicker walled and smaller ID. I used the thinner walled vacuum style.
    For those interested the thread size on the adjusting screws is 4mm .7 pitch.
    Member JimVillers's Avatar
    Jul 2012
    Virginia Beach, VA
    Search works. Perfect solution to exactly my problem. Thanks for using vBulletin with a good search function
    Jim Villers
    Virginia Beach, VA
    1961 190SL Mercedes, 1965 230SL Mercedes, 1965 356C Porsche, 1971 MGB, 1967 911 Chassis #305119
  1. WTB: 999.702.040.50 grommet for defrosters
    By 718RSK in forum Wanted: 911 Parts
    Last Post: 01-19-2015, 11:21 AM
  2. Plastic grommet to locate early door release button
    By StephenAcworth in forum Technical Info
    Last Post: 12-17-2012, 07:59 AM
  3. WTB: MFI tools (main rack adjuster + idle rack adjuster)
    By obrut in forum For Sale: 911 Parts
    Last Post: 01-11-2009, 04:19 PM
  4. FS Early Seat adjuster Rail Brackets
    Last Post: 01-03-2009, 02:57 PM
  5. Horn grommet
    By wit61 in forum Technical Info
    Last Post: 11-11-2004, 05:18 PM
