Thread: Bilsteins Vs Koni ?
    Bilsteins Vs Koni ?
    I'm still doing a bit of research into what shocks to fit to my car.
    My 2.4S is equipped with Koni 's , but it seems most people fit Bilsteins when replacing their suspension components.
    Why?
    What will the Bilsteins offer me over new Koni red or Koni yellow inserts / shocks?
    1973 2.4S
    1993 964 C2
    987 Boxster Spyder
    'hot66'
    www.ddk-online.com
    I have done both conversions. The koni shock appears to be stiffer in the sense that the ride is more tooth shattering. While the bilsteins handle just as well as the knoi's, they seem to handle challenging (bumpy/uneven surfaces) much better. The bilstein also seems to handle bumps a bit better.
    I feel that they both offer very similiar cornering characteristics.
    I love the bilstein shocks. I have used them im my 930 and S and would pick them all the time over the koni's
    If you plan to lower the car a bit, use the bilstein front struts that have the lowered spindles. Don't just buy the inserts.
    Good luck.
    RGruppe member 445
    thanks for the reply Sounds like Bilsteins are the way to go
    having looked at my struts, I'm now not convinced they are koni's. They have a single coat of black paint & no 'koni' stamp on them any where.
    I think the struts could be Boge with 3.5" spacing for the S callipers ( or A ).
    If they are Boge it means I can fit Bilsteins quite easily
    1973 2.4S
    1993 964 C2
    987 Boxster Spyder
    'hot66'
    www.ddk-online.com
  1. New Bilsteins front & back
    By Surf65 in forum Technical Info
    Last Post: 03-16-2012, 08:47 AM
  2. WTB: Rear Bilsteins for 71
    By t6dpilot in forum For Sale: 911 Parts
    Last Post: 03-10-2010, 06:55 AM
  3. Koni versus Bilsteins question for ’72-‘73
    By gtgroupe3 in forum Technical Info
    Last Post: 02-09-2009, 03:18 AM
  4. Odd Bilsteins 934?
    By parced@telia.co in forum General Info
    Last Post: 01-13-2006, 09:01 AM
  5. Green Bilsteins
    By Burzel55 in forum For Sale: 911 Parts
    Last Post: 09-01-2005, 07:16 PM
