Results 1 to 2 of 2
Thread: Torque Specs
    Torque Specs
    What are the correct torque specs for 911 valve cover nuts and sump plate nuts?
    Thanks in advance,
    Rob
    356Robo
    64 C Coupe #218448(sold)
    70T Targa #9110110416(sold)
    Longhoods forever! silverc4s's Avatar
    Apr 2003
    Somewhere in Texas
    Pretty sure the nyloc nuts on the valve covers go to 6 ft lbs only. Overtight = problems
    Not sure about the sump plate numbers, but it is likely not very high torque either, as they will really warp out of shape if the nuts are too heavily torqued.
    Bill Conway, Early S Registry member #254
    1970 S, 2.2L Silvermetallic Coupe
    1973 T, 3.2L Black Carrera Targa
    1969 T, 2.4L Silvermetallic Targa
  1. '67S Brake Bleed Screw Torque Specs?
    By Bob Schaefer in forum Technical Info
    Last Post: 06-09-2008, 10:09 AM
  2. Throttle Body Torque Specs
    By jayzoll in forum Technical Info
    Last Post: 05-01-2005, 06:35 PM
  3. aluminum lug nut torque specs
    By NiceT in forum Technical Info
    Last Post: 04-27-2005, 02:54 AM
  4. Steel Lug Torque Specs.
    By BradAndersonPHOTOWERKS in forum Technical Info
    Last Post: 01-10-2002, 09:23 AM
