Thread: fuel cap spring
    fuel cap spring
    hi, does anyone out there ever had a problem replacing the small spring that fits under the gas cap door lever, i know it sounds minor but i am haveing a heck of a time getting it in position, i think there must be a knack to it any help will be appreciated, thanks, frank
    Hi Frank,
    With the wing and filler neck still on the car it is not an easy job. Perseverance is required.
    If it becomes really hard remove the filler neck and rubber seal so you can then get your hand up underneath. This will give you better leverage/access.
    HTH
    Alan
    Oct 2004
    SW Suburbs of Chicago
    If you mean the latch spring, check this out:
    http://forums.pelicanparts.com/showt...hreadid=337969
    Mike O'Meara
    Reg #1043
    72 911T
    56,59 356s gone
    67,68 912s gone
    spring is here
    thanks alan,mike, that did the trick much apreciated, best wishes, frank
  1. SWB spring plate /SC spring plates swap
    By smedley in forum Technical Info
    Last Post: 01-06-2014, 04:02 PM
  2. Replies: 3
    Last Post: 03-09-2013, 08:14 AM
  3. Replies: 0
    Last Post: 02-11-2013, 10:19 PM
  4. Fuel door hinge spring ?
    By Greg D. in forum Technical Info
    Last Post: 12-19-2012, 05:13 PM
  5. Wiring stock fuel gauge to fuel cell; need wisdom.
    By jameshtaylor in forum Technical Info
    Last Post: 11-10-2010, 06:18 AM
