Results 1 to 10 of 15
Thread: Numbers Guru's...Name This Plz!
    67S
    body #305770
    engine #3280900
    original color Olive
    Can anyone verify what these serial numbers are???? My research shows early production '66 on the body and '68 US coupe engine (NOT an S engine). I'd really appreciate the help on this as I'm looking at buying the car but only as matching numbers...asking $5000 cdn...it IS a rot bucket but restorable as almost everything is there for it.
    All comments welcomed and appreciated...good or bad. Thanks folks.
    Paul Schooley
    S Reg #863
    R Gruppe #330
    body #305770 1967 MY 911 Coupe (Reutter) For 67 std. and S used same batch of serial numbers. Proper S has S suffix added on the chassis plate.
    engine #3280900 1968 MY type 901/14 engine 130bhp
    hope this helps
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Engine: 1968 911 Coupe 901/06 130/6100 176/4200 11830001-11830473 3280001-3281606 473
    Chassis: model year 1967 911 Coupe 901/05 130/6100 174/4200 305101-307350 907001-909000
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    I have the 901/06 engine as 911001-912050 & 3080001-3080655
    and the 901/14 as 3280001-3281606
    his engine is 3280900 or a 901/14
    My numbers are off www.elferhelfer.com, I took a look in Dr. Johnsens book and confirm your numbers, Elfer must be wrong then or....??
    Well, being that it's not numbers matching and it would cost a fortune to restore, I'm taking a pass on this one. If anyone wants it, let me know. He's asking $5000 cdn (that's like about $50 usd... )
    Paul Schooley
    S Reg #863
    R Gruppe #330
    Boxster 03 is correct in the identification of both chassis and engine. In my humble opinion even though this is a 67 car with a 68 L engine (with Webers?), the parts value of the car will be in excess of $5000.
    Your reference to the elferhelfer site prompts me to comment that this appears to be another individual that has used the data I compiled for my Original Porsche 911 without crediting the source. I was given unprecented access to the build records in Ludwigsburg (Porsche's sales and marketing headquarters) to do Original and I note the 'elfer' tables seem to reproduce mine line by line. Sorry to sound scratchy on this.
    The Brett Johnson book remains one of the best early 911 source documents on trim and colours.
    Peter Morgan
    Production information
    Peter,
    I, for one, would be very interested to see the results of your research. Forgive me, but where do I find it? Thanks.
    -Allen-
    Well, 305770 was made in the fourth quarter of 1966, which makes it a '67 model year 911 Normal. This should have had a 901/06 engine with the soft cams, although I should check the cut-over date for the cams in the little white book.
    Interesting discussion. I used that Red Book to verify my findings. Yes the car does have webers on it and a ton of great original parts. What drew my attention was when it was listed as a '66S by the owner yet the book shows differently...easy to see it was early '67 production probably 4th quarter '66. It's a great find for somebody, just not me so please let me know if ya want it folks...it's not far from my home so I can help secure it or have it delivered to my place for you to retrieve at your leisure. Glad to help someone looking for just such a beast.
    Paul Schooley
    S Reg #863
    R Gruppe #330
  1. question for the solex guru's
    By preS in forum Technical Info
    Last Post: 03-17-2011, 11:57 AM
  2. Q for 915 Gearbox Guru's
    By HughH in forum General Info
    Last Post: 09-07-2010, 11:03 AM
  3. steering wheel guru's .....
    By nickd in forum Technical Info
    Last Post: 07-22-2009, 02:30 AM
  4. Input needed from MFI guru's
    By MarkS in forum Technical Info
    Last Post: 03-29-2007, 01:56 PM
  5. Electrical Guru's Unite
    By Neunelfer in forum Technical Info
    Last Post: 09-30-2006, 10:43 AM
