Results 1 to 2 of 2
Thread: Running lights keep popping fuses.
    Help me troubleshoot my left driving lights as they are popping the fuse as soon as I turn them on. I've pulled the front housing and disasembled it. No apparent grounding. Left the housing out with no bulbs in. Still burning fuses. So I go to the rear and pull the bulbs out there. Still popping. Where to check next? Funny thing is turnsignals, reverse and flashers work fine. hmmmm
    __________________
    Joe
    '69 E Targa "Roxie"
    Early S #937
    Goldmember ttweed's Avatar
    La Jolla, CA
    It sounds like there is a hot wire shorting to ground somewhere between the fuse panel and the fixture. You need to identify the problem wire and inspect it carefully for cracked/chafed/melted insulation. If there are multiple hot wires connected to the same fuse, disconnect them all and hook up one wire at a time to isolate the one with the fault, or use an ohmmeter to check each hot wire for continuity to ground. When you have the faulty wire run identified, look all along it for insulation faults anywhere it passes close to the chassis (at clamps, bulkhead penetrations, etc.) or just run a new wire.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
  1. FS: Battery powered 914 tin models police bump & go running/steerable 914 not running
    By 88cs in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 02-12-2013, 07:38 PM
  2. engine popping
    By ferry58 in forum Technical Info
    Last Post: 04-12-2011, 08:49 AM
  3. Fuses for 67
    By tomkirkcis in forum Technical Info
    Last Post: 02-09-2010, 10:03 PM
  4. Tool kit Pudenz fuses
    By peon77 in forum For Sale: 911 Parts
    Last Post: 10-27-2009, 10:58 AM
  5. 5 amp bullet fuses
    By kilodawg in forum Technical Info
    Last Post: 12-29-2007, 10:10 AM
