Thread: Door Pockets and handles
    Senior Member 72911E's Avatar
    Jul 2006
    London / Fort Lauderdale
    Door Pockets - I want to restore my door pockets. Is it possible? or they have to be replaced?
    Interior door handles - I notice there is only a grab handle on the passenger side? Why is this? I thought originally it was taken off my car. Where should u grab the door inside to close it?
    thanks
    Aug 2006
    Chicago area
    The door pockets should be restorable depending on their condition. Do you have the al trim with the pockets? If they are warped, you can steam the material which makes it very pliable. That will allow you to reform them to the correct shape. If the pockets have broken areas, you can epoxy them and clamp two pieces of wood on either side of the repair to smooth out the epoxy. Put wax paper inbetween the repair and the wood to keep them from gluing together.
    If the fixed map pockets have speaker holes, you can use stereo cabinet press board backing to fill the hole. I got it from Home Depot - they have several thicknesses. It works great IMO and once covered in Vinyl, you really cannot tell. You can purchase flocking from an arts and crafts store to finish the inside if you choose to do that. This all depends, of course, on what condition they are in now. Good luck.
    The handle was omitted from the driver's side because it would interfere with the steering wheel ergonomics. Since I drive the car in mostly warm weather, I grab the top of the door to shut it. I try not to pull the map pocket as it deteriorates the rubber top.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    There was a great "how-to" in Esses a couple of issues ago.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Some info in this tread:
    http://www.early911sregistry.org/for...ht=door+pocket
    There was supposed to be a follow up artikcle in Esses about map pockets, but has not been printed so far.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Right hand drive cars have the passenger pull handle on the left hand door, order a arm rest for a right hand drive.
    Regis turd ab user
    Dec 2006
    Tacomatose, Wa USA
    72911E: If your car has wing windows that open, open it and pull door from bottom of wing opening at top of door skin (horizontal trim), not on vertical trim. If no wings, open window after entering or get in seat really fast!
  1. FS: Parts from a 70T Door Pockets, Door Panels & Handles
    By 76911S in forum For Sale: 911 Parts
    Last Post: 08-06-2010, 03:33 PM
  2. Door pockets, Bilstein Sports, NOS door handles
    By Unobtanium-inc in forum For Sale: 911 Parts
    Last Post: 05-29-2010, 10:46 AM
  3. WTB door handles and pockets for 71
    By GTS in forum For Sale: 911 Parts
    Last Post: 01-12-2010, 09:05 PM
  4. Door Panels/Handles/Pockets
    By creator8 in forum For Sale: 911 Parts
    Last Post: 09-04-2006, 09:06 PM
