Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Glasurit Silver 8010H or 8080?
  1. #11
    Lightbulb
    Allen is right...
    After the 60's metallic's were almost always 2 stage...
    If you were REALLY good you could get away with shooting straight single stage enamel (which doesn't exist anymore) where the technique was 'what you shot was what you got' with no 'working' the finish...
    The deal is you CAN'T work a metallic finish... you'd just sand down the aluminum flakes...what you do 'work' is the clear coat second stage...
    The German paint systems have changed at least 3 time since I did my complete in 1990... So getting the formula just right from a 35 year old chip to one of the new systems is VERY challenging...
    Also, when matching panels to exiting metallic paint is even more challenging not only because of the change of complete paint systems but with metallic's the result is both pattern AND pressure sensitive... The metallic will lay down more with slightly higher pressure, therefore and darker effect, then with a slightly lower pressure which the met. flakes will stand up creating a brighter effect.........
    I have a few old cans of color with both gun type and pressure scribbled on them from the painter...
    A good metallic complete, and moreover, a good metallic panel match, is indeed an art form today.....
    Hope this helps,
    Cheers,
    Jul 2003
    Santa Cruz, CA
    I'm not concerned with getting my paint from the matching supplier. I just want to re-stamp a replacement tag with the code it most likely had when it left the factory.
    So, all you 8080 people out there, are you Hs, Ls or Gs?
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  3. #13
    Jan 2003
    NW Indiana
    Quote Originally Posted by 70SATMan
    On a related note. My 70 is missing it's tag. I know the code for my car is 8080 but, how would I determine the paint supplier since that is not on my COA?
    Guess? Which letter, G, L, or H, do you like the most and stamp it on the tag. At this point you can't figure out which paint maker was used.
    Brian
    '71T
    R Gruppe #299
  4. #14
    Where are the CSI lab guys when you need them
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
  5. #15
    My 70S is an 8080H
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
  6. #16
    Jul 2006
    Corvallis, OR
    So, if you were restoring a 72S needing a complete paint job from bare metal where and what paint would you recomend for silver mettalic 8080? I want to do this right the first time and what would be considered a concour resto done right. I didn't know if a clear coat was what they used in 72 or if that's aceptable today on a resoration.
  7. #17
    For the highest standard
    Concours repaint...
    Is that what you really want? then you have to find a proven Porsche painter who has painted cars that have won top tier Porsche awards. If you can't find one in your area then you have to transport your car or get lucky.
    -Allen-
  8. #18
    Nov 2003
    Sydney
    8080....
    Michael,
    I went through this frustrating excercise several months ago.
    I wanted to contact Mark Waring in the UK for help as my car is a UK delivery and he has some listings that would be of interest in this area but was unable to make contact.
    I also asked at Porsche Cars Australia as they have a factory microfiche of 911s produced in that era but also to no avail.
    The last resort was to use the 'pin' method...G,L or H...? which was what I ended up doing.
    Let me know if you can do something a little more scientific pls...
    Cheers,
    Dennis.
    S Registry member 536
  9. #19
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by fryardds
    See, now that's the kind of talk that makes me dig my heels in.
    Did you say that on purpose?
    OK, I have one data point. Dave, what's your build date? Mine is 1/1/70.
    What has me thinking is that Karmann and Reutter might have sourced paint differently giving us different manufacturer suffix stamps for the same color.
    Another theory might be that colors that Porsche picked out might not have been available from all three suppliers. For example, maybe all 8080 at that time was Herbol.
    Lastly, a color was available from multiple suppliers but, at a particular time they could only get 8080 from Glasurit. Since the paint would have been bought in bulk, it would lead to a number of cars built in the same time frame of say a month or two and in the same color. They would have all ended up with the same manufacturer suffix.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  10. #20
    I am not sure of my build date, but I am very late in the model year series. Is there an easy way to figure this out?
    10 sec 67 VW
  1. 8080 = 924 or 925 body color?
    By Rino71 in forum Technical Info
    Last Post: 04-12-2013, 09:41 AM
  2. Early Glasurit
    By mrimorton in forum Technical Info
    Last Post: 04-17-2011, 06:06 PM
  3. Jim Goes For Glasurit Silver Metallic...Stunning!
    By FHernand in forum General Info
    Last Post: 11-15-2010, 05:17 AM
  4. Glasurit Codes
    By Mr9146 in forum General Info
    Last Post: 03-07-2008, 06:55 AM
  5. Simple paint question - Glasurit
    By Justin in forum General Info
    Last Post: 02-01-2005, 10:16 PM
