Results 1 to 9 of 9
Thread: Red fan shroud refinishing - paint or dye?
    My red fan shroud has been painted in the past & I am now wanting to refinish it for a more original finish.
    My plan is to strip off the paint using paint stripper.
    Doing a search I found this thread :
    http://www.early911sregistry.org/for...ght=shroud+red
    where chuck demonstrates how to restore the finish.
    Do most people refinish using this method or should I repaint the shroud?
    1973 2.4S
    1993 964 C2
    987 Boxster Spyder
    'hot66'
    www.ddk-online.com
    Nov 2003
    Santa Monica CA
    Refinish fan shroud
    In my thinking the red dye that Chuck Miller describes is one of the best options. This was also printed up in the Esses magazine from the Early S Registry. Paint does not stick to fiberglass very well. It might take a couple of applictions of the dye. Regards Chris Early S Reg. #205
    Jan 2003
    NW Indiana
    James,
    I did the CM dye method to my RS red shroud when the motor was rebuilt and it turned out real nice. The red shroud on my 2.2S was a different story. It had been painted but was basically un-useable due to degredation of the fiberglass. I bought a reproduced one from Damon at Series 900 and was really pleased with the outcome.
    Brian
    '71T
    R Gruppe #299
    That looks very nice
    I am going to be stripping the paint off today. Hopefully the shroud is in good condiion beneath the paint.
    Another method that has been suggested is to use Autoglymn Bumper restorer on the shroud. Apparently this works really well
    1973 2.4S
    1993 964 C2
    987 Boxster Spyder
    'hot66'
    www.ddk-online.com
    stripped off the paint & discovered why it had been painted
    1973 2.4S
    1993 964 C2
    987 Boxster Spyder
    'hot66'
    www.ddk-online.com
    Quote Originally Posted by james
    James - I spoke to Lee earlier today and gave him your number - he'll call you and see if he can repair / replace the gel coat to refinish it
    Philip
    1973 911 Carrera RS #496
    Early 911S Registry #1808
    angry mechanic
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Had family around all easter so not managed to spend a huge amount of time on the shroud, but here are the results :
    'wet & dried' the worse areas of the fibreglass with a fine grade. Followed this with some cutting compound I had, farecla G4.
    Folowed this with the Autoglym Bumper care
    From this:
    to this :
    The 'light' is different for this photo, but it is a deffinate improvement
    Of course the gel coating is still cracked & the shroud will never win a concours, but for an approx outlay of £5 it looks OK ish.
    I'm not quite sure what to do now. The shroud is presentable, but still not upto the quality of teh rest of the car .... but it is the original shroud & does show 'patina'
    Or should I save my money up to do it properly / find a replacment ?
    1973 2.4S
    1993 964 C2
    987 Boxster Spyder
    'hot66'
    www.ddk-online.com
    Nice work. I'd keep it until you find one better. It could be a long wait. Nice patina, too!
    PS - For the reproduction mentioned above:
    Damon Josz at Series 900 in Sunapee, NH - 603/863-0090 or email him at series900@nhvt.net
    Peter Kane
    '72 911S Targa
  1. Fuchs refinishing
    By cjannelli in forum Technical Info
    Last Post: 06-08-2012, 11:23 AM
  2. Fuchs Refinishing
    Last Post: 11-06-2009, 09:11 AM
  3. Engine Shroud Refinishing
    By D Moran in forum Technical Info
    Last Post: 06-07-2009, 04:21 PM
  4. Refinishing the Fan
    By 2POINT7 in forum Technical Info
    Last Post: 01-13-2008, 10:11 PM
  5. Fan Shroud paint
    By Walter Stockton in forum Technical Info
    Last Post: 12-30-2002, 04:13 PM
