lock insert. Pulling my friggen hair out on down hill slide to complete interior . Looking for aluminum trim 'see attached pic' that fits on the bottom of the top interior door trim. Need driver side but can make a passenger side work. Also in need of the round plastic insert that goes in the top the the same inside door trim, that the up to unlock down to lock button goes through. I BELIEVE this aluminum trim piece was used on S cars only but maybe wrong, I hope. Mine is a 67S but believe 68S had the same piece and the lock insert from any early SWB is the same but again I may be wrong. While I'm at it could also use a nice pair of rear quarter panel black vinyl trim pieces. Thank you
