Results 1 to 8 of 8
Thread: CV bolts
    Aug 2005
    VA
    CV bolts
    I replaced all four CV joints on my car 6 months ago because the boots were tearing and the bolts were backing out (plus they had 150k mi on them).
    I adjusted the parking brake yesterday and noticed a couple of the bolts had backed out. I used new lock washers and new bolts on the new CV joints. Any tricks to the trade to keep them from backing out? Thought I was done messing with the CV's for a while.
    Chris
    73 911 E
    Dec 2002
    Birmingham, MI
    Use new Schnoor serrated lock washers. Make sure you clean all the grit and grease away from the bolts - especially the threads and those in the hole. Use a test tube brush and/or a Q-tip dipped in brake cleaner until you don't see any more grease on it. Torque properly. I have seen them drilled and safety-wired before (one each), but I think it's overkill... then again, I've never had one come loose at speed (knocking wd).
    Check torque after 500 miles. Lots of info on Pelican re: this subject.
    Jared
    '73 911S #0793
    '69 912_ #0602
    Early S #0454
    RGruppe #0391
    Mar 2005
    Who sells these Schnoor washers?
    Don
    1969 911S
    1976 914 2.0
    1981 911SC
    Dec 2002
    Birmingham, MI
    Pelican sells them. Do a catalog search for "cv joint lock washer". Also McMaster-Carr.
    Jared
    '73 911S #0793
    '69 912_ #0602
    Early S #0454
    RGruppe #0391
    Mar 2005
    They seem to be no longer available at Pelican.
    I once drilled and safety wired the CV bolts on my 914-6, and will not do this again.
    As we all know (and I should have), safety wire only keeps the bolt from coming out - it does not keep it tight. My bolts loosened a bit, but I could not retorque them with the safety wire in place. I just made more work for myself.
    THe answer, as stated, is new serrated washers and proper torquing. I suppose a bit of loc-tite couldn't hurt...
    Lee
    Apr 2003
    Portland, OR
    Quote Originally Posted by dhopkins
    Try McMaster Carr @ http://www.mcmaster.com page 3144
    Belleville Spring Lock Washers, Serrated, Nonserrated
    Also called conical washers, these washers resist loosening due to heat and vibration. Serrated— Small grooves grip by uniformly pressing against surfaces. Nonserrated— Wider and stronger than serrated washers. 18-8 Stainless Steel —Excellent corrosion resistance. May be mildly magnetic. Rockwell hardness is C38-C52 for inch sizes and B80 for metric. All steel washers are made of C1060-C1075 steel. Rockwell hardness is C42-C52. Black-phosphate steel is mildly rust resistant. .
    Harry
    Member #789
    2009 MB C300
    the Dealer has them - be sure to get the right size for the year car you have
  1. FS: SWB Eye Bolts
    By juche_namja in forum For Sale: 911 Parts
    Last Post: 10-24-2014, 07:40 AM
  2. FS: eye bolts early
    Last Post: 04-29-2012, 08:10 PM
  3. FS: New in box - 2.0L ARP Rod Bolts
    By kenikh in forum For Sale: 911 Parts
    Last Post: 07-01-2009, 12:17 PM
  4. 65' Hinge bolts
    By rcnagel in forum Technical Info
    Last Post: 05-30-2009, 10:54 PM
  5. 2.2 rod bolts?
    By 0687 in forum Technical Info
    Last Post: 03-02-2007, 11:27 AM
