Thread: rear quarter window installation
    I am putting in the rear quarter windows in a 1970 and since I didn't take them out I am not sure if I have all the pieces.
    It seems there is a white plastic channel that covers the top metal "flange" but nothing for the front or bottom. Does the lower chrome trim cover the "flange" and is there some type of sealant for this piece? Is there any trim inside of the "flange" that covers the painted surface or is it only covered by the trim piece tha covers the side panel?
    Thanks for the help, I looked through factory books and others that I have but I can't seem to figure it out.
    Jule
    Jule,
    May be of some help - I recently parted a '69 and the alu trim covered the lower seam, white plastic on the top seam (as you have noted) and black plastic on the vertical seam. Note that the colour of plastic trim matches the headliner (white) and pillar vinyl (black). Also, under the Alu trim piece there are fibre washers against the paintwork at each screw location as well as mastic sealant along the full length.
    Karsten
    Karsten,
    Thanks for the reply.
    So it is somewhat what I thought, now I have to look for trim
    pieces.
    Jule
  1. Replies: 1
    Last Post: 03-20-2014, 05:24 PM
  2. Quarter Window Outside Trim Installation
    By JimVillers in forum Technical Info
    Last Post: 08-24-2013, 09:59 AM
  3. Rear Window Trim installation question
    By T308 in forum Technical Info
    Last Post: 12-14-2012, 08:50 PM
  4. FS. NOS right rear quarter window, 68-77.
    By Burint in forum For Sale: 911 Parts
    Last Post: 06-04-2008, 07:55 PM
