Results 1 to 2 of 2
Thread: Round Relay Questions
    Jan 2006
    Naperville, IL
    What can you tell me about the round relays that are found in our cars? I am primarily looking for amperage ratings and wiring diagrams.
    Is there any reason that I should not use these as headlight relays that will support 100 Watt bulbs?
    Also, what is the difference between the red and black relays?
    Any help is appreciated
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    I just replaced one of the black relays for my fan blower, rear defrost and trunk lite in my 69.
    Haynes manual has wiring schematics, but I don't think they show the values of the relays or the wiring hookup. Daniel Stern lighting has a schematic of how to rewire for modern high watt lighting. I did not use this black relay or stock wiring when I upgraded to H4s and driving lights. If you need to keep everything for concours, then run stock bulbs. Otherwise, I'd suggest using modern relays with larger wire.
    Joe
    '69 E Targa "Roxie"
    Early S #937
  1. WTT: MFI Relay for MFI Relay (see part numbers in ad)
    By denson in forum Free, Trades, and Swaps
    Last Post: 12-29-2013, 05:31 AM
  2. WTT: MFI Relay for MFI Relay (see part numbers in ad)
    By denson in forum For Sale: 911 Parts
  3. New Round here.
    By jos.hall in forum General Info
    Last Post: 06-25-2012, 05:27 PM
  4. Replies: 4
    Last Post: 01-03-2011, 05:31 AM
  5. 6's n' 7's or 7's all round??
    By gilbert911 in forum General Info
    Last Post: 02-14-2007, 03:28 PM
