Hi,
I need this section (see photos) to replace a rusty one on my 72 coupe. It need to be cut outside factory joint be be able to replace it and look like a factory job.
I will be in Hershey if you can bring it !
Hi,
Nobody is parting out a early body ??
JD
Probably nobody has one that is rustfree ..Nobody is parting out a early body ??
Richard
Check with Rick2. He has an early roller coupe he is parting out and I recall him mentioning that the rear package shelf on the car was rust free. He also owns a blow torch!!!
I had good luck sourcing one of these for my '70 from a Porsche salvage yard (EASY). They did a reat job cutting in the right places, and shipping was much less that I expected. It was rust free!
Early S Registry 1047
’15 VW GTI
'70 911E, Sold
'56 Cliff May Prefab
I need one of those also but I found the piece to be different on the 70 than the 72. I had a 70 coupe ready to cut out for the 72 but the tabs as well as the stamp of the shelf were different.
Yes, there was a major redesign of that part of the car. This should make it easy, though, as I imagine you could use galvanized panels from a later car.
’15 VW GTI
'70 911E, Sold
If I rember right. I went thru this last winter. 69-71 are pretty much the same. 72-73 are the same, the change was made for a more ridged cab and the introduction of the 915 Trans (the rear seat wells changed as well). 74-till the late 70' the same galvanation was the plus. As all ways it is very easy to back date and gain the advantage of the up date. It just depends how Correct you want it.
I purchessed a whole roller just to get a package tray and rear seat pannel. The body arrived and it was in such good shape I could not bring my self to cut it up. Its had front and center in the garage for about 6 months now. And there sitting bare to the metal.
Bill Barnich
R Gruppe Nr.230
Early S Nr.960
71 911T/2.7 Tangarine
73 911?/3.6 work in progress
Yep, mine is from a 67/68 and the stamping is different. Mine is rust free if someone needs the back half of the car or some front pieces. I would recomend them sawzalling it off though to keep down the warpage.
Rick
67 Normale, Old Rusty
67 R Inspired and on a Diet
73 T/ST Caged Beast
RGruppe #383
S Registry #739
