Results 1 to 2 of 2
Thread: Dashbord pieces missing?
    Hi
    I bought this dashboard some months ago, and I am about to prepare for installation in my car. The dash presently in my car is a pre 69 dash and the one in the pictures is a 1969-up dash.
    Am I missing some plastic "pegs", the white ones that goes into the holes in the sheet metal that the dash is mounted on top of? If so how do I repair/install new ones and where can I get them?
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    The square holes take a particular screw with a flat attached. It fits into the hole and you rotate it. When you mount the dash this then goes through the metal (frame) dash and is held with a nut and washer. The white plastic parts are called fixing clips and their are "bushes" that go into the metal dash that hold these.
    I've attached the photo and part numbers.
    Good luck.
    Tom
    Early S Registry #235
    rgruppe #111
  1. Replies: 25
    Last Post: 10-27-2014, 06:12 PM
  2. What am I missing here ?
    By Mrzoop in forum General Info
    Last Post: 09-04-2012, 08:17 AM
  3. basket wave lower dashbord vinyl trim
    By xenifizi in forum General Info
    Last Post: 02-24-2009, 01:38 PM
  4. Steering Wheel missing pieces?
    By Dmill in forum Technical Info
    Last Post: 05-03-2007, 10:23 PM
  5. Steering Wheel missing pieces?
    Last Post: 05-02-2007, 02:13 PM
