Thread: Is 69 tranny ground strap different?
    Mar 2005
    I need to put a ground strap on my 69S but Pelican only has one for 1972-1989. Will the one sold by Pelican be correct? From the picture it looks like it might be on the long side. Anybody know?
    Don
    _________________________________________________
    1969 911S
    1976 914 2.0
    1981 911SC
    I've never really had reason to measure any length difference, but I can see where maybe the 915 trans might use a longer strap, but I can't imagine the difference would be all that great. I guess if you really want to be sure, wait and get the correct part number from Porsche. I'm sure Stoddard will have it.
    Senior Member Grady Clay's Avatar
    Sep 2004
    Unincorporated Arapahoe County, Colorado, USA
    The ’72 and later transmission ground strap (999.611.920.20) is wider and slightly shorter than the ’71 and earlier strap (999.611.918.20).
    Best,
    Grady
    Dec 2002
    71236 Brush Rd. Niles, Mi. 49120
    ground strap trick!
    I run two ground straps on my 67 911s one little stock strap from nose of trans. to chassis. Then a pice of plastic coated battery cable with a small eye gromit under starter lower nut and loop it out ofthe way (wire ties) back to noise of trans and then on the ground stud and tighten on the nut.
    After I did this I eliminated all hot starting probelms from running on tracks. A old German VW repair shop did this on old 6V VWs.
    Grover #53
    1967,911-S
  1. 73 S - engine lid ground strap?
    By mac73s in forum Technical Info
    Last Post: 07-28-2013, 01:47 PM
  2. Replies: 9
    Last Post: 03-24-2013, 12:48 PM
  3. Battery Ground Strap
    By boxster03 in forum Technical Info
    Last Post: 02-21-2010, 08:23 AM
  4. FS Wingnuts...Really! Ground strap
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 05-23-2007, 08:18 PM
  5. Original Battery Ground Strap?
    By bobmagyar in forum Technical Info
    Last Post: 07-17-2006, 04:42 PM
