Thread: Pls. help ID
    Pls. help ID
    hi everyone,
    pls. help me ID a car i just bought.
    VIN# 9112510361 (coupe or targa)
    Engine # 6390147 (2.4 or ???)
    thank you!!
    benji
    www.spyderautomobiles.com .au
    Feb 2005
    Australia
    Hi Benji,
    VIN denotes 1972 TV-E Targa (2.4 with carbes)
    Engine number OTOH is for late 2.0L S (with MFI, not carbes).
    Hopes this helps.
    Cheers,
    Lisa
    Lisa Gregory
    Early 911S Registry #726
    www.spyderautomobiles.com.au
    id help
    thanks for the info lisa!
    i'm really confused because the porsche red book states that it is a '72 coupe and the engine is a 3 liter from an sc. what reference book did you use?
    Feb 2005
    Australia
    Well memory really ...
    But here's confirmation from the Porsche Technical spec books:
    VIN# 9112510361 : model year 1972 Targa chassis number range 911 251 0001 - 911 251 1523. The 6th digit being a "1" signifies Targa; if it was a Coupe that digit should be "0".
    Engine # 6390147 - well it is a 1969 2.0L S number; engine type 901/10.
    It is also a 1979 ROW SC number for engine type 930/09 (I think the type is right).
    So - what do you think you've got?
    Lisa Gregory
    id
    hi lisa,
    i think you're correct on the chassis. i will have to check on the engine casse to check on whether it's a 3 liter or a 2.0. i'm hoping that it's a 2.0S!
    thanks again!
