Results 1 to 2 of 2
Thread: water tight targa?
    water tight targa?
    hi all, i realize this is probably a dumb question but here goes. how water tight were the early targas when they were new? it's hard to imagine them being dry when driven in anything more than a light rain. are modern seals any good? any suggestions on a recommended supplier? thanks
    Nov 2003
    Sydney
    I had a '75 Targa for 13 years that had been restored and it was quite dry when hose washed or in a rainstorm.
    If a new car leaked,I would imagine Fritz on the production line would have had his a$$ kicked for poor workmanship !
    Those were the days of 'Made by Hand'.
    I wouldn't go past Porsche's own seals for quality and fit despite the price.
    It is an area that MUST be right !
    If you are contemplating a restoration,then you also MUST ensure the rectangular Targa top opening is within specifications otherwise you are wasting your time / money going any further.
    The windscreen pillars sometimes are not always square to the Targa bar due to aging and need to be bent !
    Cheers,
    Dennis.
    S Registry member 536
  1. Where's this water from?
    By joetiii in forum General Info
    Last Post: 09-13-2015, 02:47 PM
  2. Trailing arm w/bushing to tight for chassis mount :-(
    Last Post: 04-13-2011, 08:29 PM
  3. Tight clutch on '68 911
    By Fritter in forum General Info
    Last Post: 06-03-2009, 11:47 AM
  4. Should water be in there?
    By sgat_555 in forum Technical Info
    Last Post: 12-15-2004, 09:16 AM
  5. Adjusting valves too tight or too loose
    By apokon in forum Technical Info
    Last Post: 03-17-2004, 03:46 AM
