Thread: need help with dismantling a 380mm wheel
    I tried removing the 4 screws deep inside the rear, what to do about stuck screws, I guess thats where I'll find the numbers, right?
    Do I need to drill those out?
    newbie in need of tech advice
    appreciate the input, thanks
    Richard aka le Zookeeper
    early reg #1128
    Goldmember ttweed's Avatar
    La Jolla, CA
    Before you give up and drill them, give it a good soaking w/ penetrating oil--PB Blaster and Kroil are often mentioned as favorites. Get a manual "impact" screwdriver, like this one, use exactly the right size and type of bit to fit the slots in the screw heads, and give them a bang with it after soaking overnight. You might get lucky. The combination of striking downward with a hammer while the driver twists will give you the best chance. After you mangle the top of the screws, you can go ahead and drill them out.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Jan 2003
    UK
    "I guess thats where I'll find the numbers, right?"
    Are you referring to the part number & date ?
    If so, these are stamped into the front face of the hub, underneath the horn pad.
    Andy
    Early 911S Reg #753
    R Gruppe #105
  1. Dismantling and reassembly of door frames
    By Andy 74 in forum Technical Info
    Last Post: 03-12-2022, 10:31 AM
  2. Stripping/dismantling the door of a 66 911
    By MTemp in forum Technical Info
    Last Post: 05-12-2011, 09:34 PM
  3. 380MM 73 RS Wheel
    By Rennman in forum For Sale: 911 Parts
    Last Post: 11-13-2010, 05:22 PM
  4. Dismantling Cibie hood lights???
    By obrut in forum Technical Info
    Last Post: 05-31-2006, 08:46 PM
