Results 1 to 7 of 7
Thread: How much psi does stock 69S pump make?
    Mar 2005
    Anybody know the answer to this question? I am switching to PMOs and need to decide whether I need a new pump.
    Don
    ___________________________________________
    1969 911S
    1976 914
    1981 911SC
    2001 C320
    Don, you need a pump and a pressure regulator.
    Juan - Member # 321
    Ft. Lauderdale
    Klub Sport Champion
    Rolex Endurance Champion
    HSR Sprint Champion
    PCA Club Race Champion
    Doesn't the PMO kit come with a regulator?
    If you mount a 4 psi pump on the front crossmember, you'll have about 3-3.5 psi at the carb inlets, and without a pressure regulator (confirmed with an inline pressure gauge). KISS. Here's one by Airtex that I use:
    Sherwood
    Mar 2005
    Thanks. It does come with a regulator/meter. But I was leary of having to regulate down a lot if the OEM pump was really strong. I found in the workshop manual that the pump put out 11.8+/-3psi. Thanks.
    The MFI pump will go 35-40 psi, the 11.5 psi mentioned in the manual is what the return side is regulated to by the check valve in the banjo fitting. Use the 4 psi pump as was suggested.
    Mr. Mayo:
    I truly enjoy the advice you give on the PCA web site about our early cars that regularly makes its way into my Inbox!
    Peter Kane
    '72 911S Targa
  1. Make your own MFI Pump Gaskets
    By michael70st in forum Technical Info
    Last Post: 03-04-2013, 04:40 PM
  2. Did Porsche make one of these?
    By a94rsa in forum Technical Info
    Last Post: 02-12-2013, 10:43 AM
  3. Can't make it go!!!
    By LDunville in forum Technical Info
    Last Post: 05-16-2012, 05:54 PM
  4. Make your car look like a toy
    By classic in forum General Info
    Last Post: 02-02-2009, 10:04 AM
  5. The 68L make over...?
    By bob tilton in forum General Info
    Last Post: 02-24-2006, 07:52 AM
