Results 1 to 9 of 9
Thread: Buying '70 911S, are these engine/VIN numbers matching or at least close?
    Hi there,
    I have a chance to buy a '70 911S, which is VIN XXXXX0519 and engine number XXX0081. The other numbers are correct for a '70 S but the production number for the chassis and engine seem far apart to me.
    How can I tell if this is a numbers matching car? Is there a way to confirm that the numbers match without getting all of the info that comes with the $100 (and three month wait) certificate?
    How far off can the numbers be? 400+ seems like a lot.
    Thanks for your help.
    Seems like quite a spread - My restoration project is # 0247 and has engine # 0344 - correct as per COA.
    AM
    If the car has the original service manual the engine number should be recorded in that.
    Phil
    I have the following COA's for 911 S's
    1969 119301268 Engine # 6391817
    1969 119301269 Engine # 6391798
    1970 9110301201 Engine # 6301622
    1973 9113301092 Engine # 6331731
    It seems possible to me that this original engine.
    Phil
    Senior Member gtgroupe3's Avatar
    Sep 2006
    MD
    More Chassis & Case Numbers
    Here are some more numbers which bracket your 70S Chassis (0519/0081).slb
    Chassis# Case#
    9110300400 6300564
    9110300445 6300634
    9110300557 6300785
    9110300596 6300805
    it is possible but documentation is only real proof.
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    The COA's are taking about 3-4 weeks to get right now, they leave a lot to be desired but they do have engine serial #.
    Phil
    Its not very likely its correct, its to far off. Get a COA or send the factory a mail like I did. The second time I got the head mecanic at my P. shop to send them a mail. But who knows, maybe they put one of the early engines aside, and installed it in a later chassis?
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Longhoods forever! silverc4s's Avatar
    Apr 2003
    Somewhere in Texas
    Here's good data point for you - I have 1970 S Coupe VIN #40, the engine number is 78. All original, and I have the COA as well.
    Bill Conway, Early S Registry member #254
    1970 S, 2.2L Silvermetallic Coupe
    1973 T, 3.2L Black Carrera Targa
    1969 T, 2.4L Silvermetallic Targa
  1. 1969 911s value matching numbers vs non matching
    By frankmar in forum General Info
    Last Post: 02-26-2015, 09:53 AM
  2. FS: 1973 911S Coupe | Driver | Matching Numbers
    By PNW 73S in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 04-11-2014, 09:49 AM
  3. numbers matching engine
    By Christopher p Steimer in forum Technical Info
    Last Post: 08-22-2012, 12:15 PM
  4. Matching numbers 1971 911S for sale
    By thevojtiseks in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 06-18-2008, 06:56 AM
