Thread: 901 Gearbox External Lubrication Kit
    Hello,
    Does anyone have any idea if someone produces a 901 gearbox external lubrication kit like that shown on Armano's website, particularly those pieces shown in the oil lines section which mount on the case? I've spoken to him and also Bernie, who's installing it on his case, who suggested that I try to locate a reproduction kit prior to getting one fabricated. Any help would be most appreciated. Thanks.
    Hello:The easiest thing to do is use a electric pump to lube the gearbox. Install squirters using AN fittings and -4 lines. You will have to make a manifold to supply all the gears and ring/pinion. Hope this helps. Thanks Eric
    Senior Member Grady Clay's Avatar
    Sep 2004
    Unincorporated Arapahoe County, Colorado, USA
    Bill,
    Talk to Chuck Moreland at Elephant Racing. He (and I) are working through the process of finding the best solution (technical and economic). His application is a Type 911 transmission in a later 911 race chassis. Mine is a Type 911 transmission in a 914-6 race car. Both are applicable for your use.
    There are several serious threads about this on Pelican.
    Best,
    Grady
  1. 911 S without external oil cooler/lines ?????
    By J.Puppi in forum Technical Info
    Last Post: 05-14-2015, 10:12 AM
  2. Need help with 28 Row external oil cooler tab
    By Haasman in forum Technical Info
    Last Post: 07-15-2013, 01:32 PM
  3. SWB external oil line suggestion...
    By andrea70 in forum Technical Info
    Last Post: 02-12-2012, 01:33 PM
  4. Speedometer Cable Lubrication
    By Brad Davis in forum Technical Info
    Last Post: 05-03-2010, 08:02 PM
  5. WTB: Clutch lever -- external -- for '72 911
    By Eminence Gris in forum For Sale: 911 Parts
    Last Post: 05-18-2008, 05:48 PM
